12V battery still testing good on 2012 Prius C
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by LindaOwnsAPrius, Mar 16, 2023.
  1. LindaOwnsAPrius
    LindaOwnsAPrius Junior Member
    San Francisco
    2023 Prius Prime
    XSE
    My 2012 Prius C has 60,500 miles on it-- it just had its 60k inspection.
    I'm the original owner & the 12V battery date is 11/2012-- the original battery.
    The 12V battery results from yesterday:
    Tested 12V battery with loads on. After one minute, it drains to 11.5Volts.
    12V battery is in good condition.
    My question is: should I replace the 12V battery? It's 11 years old & even though it's still strong, am I taking a risk by not replacing it now?
  2. Leadfoot J. McCoalroller
    7,173
    6,722
    Pennsylvania
    2018 Prius c
    Time to replace it.
    Sure it still works as long as nobody leaves a door ajar all weekend in the garage or something like that. That would completely kill an old one like that.
    LindaOwnsAPrius likes this.
    49,490
    You’re living on borrowed time. Either replace it now, or buy a small jump box for when it quits on you, so you don’t get stranded
  4. LindaOwnsAPrius
    San Francisco
    2023 Prius Prime
    XSE
    good point.. thanks for the response. I'll get the battery replaced asap
    thank you for this… I’m definitely going to replace it
    #4 LindaOwnsAPrius, Mar 16, 2023
