12v battery sudden failure at 33 months
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by jhg, Nov 4, 2008.
  1. jhg
    jhg Junior Member
    30
    The 12v battery on my 06 Prius died very suddenly. I was able to easily jump start it from another car. I called around to various battery and auto parts stores and could not find a compatible battery, and ended up having to pay the dealer $200 for the battery ($170) plus installation and fees.
    This is unconscionable profiteering IMHO.
    Anyone know the best channel for filing a complaint and registering my displeasure?
  2. rigormortis
    rigormortis Active Member
    1,340
    26
    san jose, ca
    you should of searched here more. using the mazda miata battery + japanese post adapter would of worked too. its really popular here. gets a lot of good reviews
  3. Rokeby
    Rokeby Member
    3,033
    709
    75
    Ballamer, Merlin
    jhg,
    Welcome to PriusChat.
    Typically, the recommended 12V battery replacement interval is 4 years.
    But hard service and extreme temps tend to reduce that number.
    For the record, how many miles are on your car?
    Do you live in a very hot or cold climate?
    Other than the final incident, did you ever have to recharge the battery
    before?
  4. jhg
    jhg Junior Member
    30
    Thanks Rokeby,
    I have 46K miles, none of it high-stress. I live in Austin, TX so summer runs from early May thru the middle of October, and the last two winters have been non-existent (4-5 days below freezing each year).
    The battery failed completely without warning. It started fine in the morning, and was completely dead after a stop at an errand at 3:30 PM. Pressing START resulted in nothing but a very dim Check Engine light that faded out quickly. After hooking up the jumper cables it started immediately, and I was able to drive it to the dealer normally. There was a smell of H2S around the battery, but no evidence of any leaking fluids.
  5. Patrick Wong
    18,200
    6,493
    The Prius battery sold by the dealer is manufactured in Japan (not China) and therefore is quite costly. As you discovered, it is not easy to find a cost-effective substitute unless you are willing to install new battery terminals.
    Since you are driving >15K miles per year, lack of use does not seem to be a problem. My guess is that your battery's failure after two years was a fluke.
  6. rigormortis
    1,340
    26
    san jose, ca
  7. ibcs
    ibcs New Member
    351
    31
    Englewood , Ohio
    Mine died at 33 months and 47,000 miles. Had the dealer replace for $223 out the door. The only failure I've had to date.
    ---Kent
  8. richard schumacher
    7,664
    1,043
    United States
    If you feel up to doing a little work yourself, a much better though no cheaper Optima battery installation is described here:
    Prius Optima Aux
    That page includes a link to a seller of the Optima and a custom installation kit.
