12v battery was disonnected, parking malfunction
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Jaydoc, Dec 6, 2015.
  1. Jaydoc
    Jaydoc Junior Member
    30
    Birmingham
    Hi all
    I had the 12v battery of my Prius 2010 disconnected to install a backup camera, but then had a change of plans, so after a couple of hours I reconnected it. But when I started the car I got a yellow triangle exclamation and this error message -"p lock malfunction when parking , park in a flat place and apply parking brake securely".
    The car starts, shifts into reverse and drive, and does not roll on a flat surface when turned off.
    How can I fix this?
    Thanks.
  2. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    Ignore the error. If you don't get any more errors with subsequent starts, don't worry about it.
  3. Jaydoc
    30
    Birmingham
    Thanks @xliderider . I have taken the car for a drive, parked it on some pretty steep slopes, but the parking light on the center console does not work, and the park indicator does not get highlighted. But when I turn off the car, it does not roll.
    I also installed a new head unit. There was a bolt that slipped and fell into the central console housing. I tried reaching it and gave up. I am unsure if I accidentally disconnected some wiring underneath it.
    The error is persistent and comes on with each restart.
  4. JC91006
    16,482
    8,400
    what's your battery health/voltage?
  5. bisco
    49,479
    the p lock malfunction is a warning and usually nothing to do with the parking lock. if the battery is good, recheck your wiring.
  6. Jaydoc
    30
    Birmingham
    1. My battery outputs 10.6v when the car is on but no accessories are on.
    2. Which wiring? I have a few wires that need to be tucked away from the head unit I installed. Would that be a problem?
    Thanks.
  7. JC91006
    16,482
    8,400
    time to change the 12v battery
  8. bisco
    49,479
    ,battery connection wires. but if you're reading 10.6 at the battery posts with a meter, it's toast. you could try charging it, how old is it?
  9. Jaydoc
    30
    Birmingham
    I don't think it's been replaced, but I am not sure. In any case, I never had this problem today before I disconnected and then reconnected the battery negative terminal? I never had this problem before today. There was some sparking when I put the bolt back on the terminal post. Could that be the issue? If so I will take it to a mechanic to replace the battery.
  10. bisco
    49,479
    i doubt it. did you test it at the terminals?
    wait, you can install a head unit, back up camera, but not a 12v battery?
  11. JC91006
    16,482
    8,400
    The issue is the battery is at least 5 years old and is reading only 10.6 volts. A new battery should read around 12.9 volts
  12. Jaydoc
    30
    Birmingham
    @bisco
    I haven't installed the camera yet. Will do so in a week. And yes, I can follow instructions pretty well when doing something. If I find some clear instructions on how to change out the battery I will try it out myself.
    @JC91006
    I will try the battery change and will let you know.
  13. bisco
    49,479
    there are threads here with pics, it's not hard at all. all the best.(y)
  14. mrbigh
    3,686
    699
    Long Island, NY
    you have a 2010 with the original Aux battery??????????????????
    It is time to replace it, it doesn't last with a good state of health more than 5 years............
    My choice was the correct Optima Yellow top.
