12V battery won't charge anymore
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Jason Schwartz, Feb 23, 2015.
  1. Jason Schwartz
    Jason Schwartz New Member
    Wondering if there's any advice beyond the obvious (i.e., get a mechanic!) for this issue.
    Ex-wife has 2006 Prius with original 12V battery. Since about October, this battery has dead and the car wouldn't start on average once a week. Using a portable charger, I was able to revive battery/car the first umpteen or so times, always with the warning, "Julie, you really need to take the car in."
    Well, finally we are at the point where even the charger won't save the battery. I am now advising Julie to DEFINITELY call the mechanic. However, she is insistent that there must still be a DIY free thing we can do, even with neither of us having any particular mechanical knowledge or prowess.
    (And lest you all make fun of me for even worrying about my ex-wife's car, note that she is responsible for my young son half the week and Chicago's not a great walking town for him this time of year.)
    Thanks!
  2. Paradox
    29,110
    8,591
    201
    2014 Prius v wagon
    Moved to the Gen II maintenance and troubleshooting forum from the Prius v maintenance and troubleshooting forum.
  3. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,800
    Undisclosed Location
    Your Ex has a 2006 with the original 12 volt battery?
    It's 2015, time to get a new 12 volt.
    I don't think you necessarily need a mechanic...but somebody needs to install a new 12 volt battery.
  4. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    most Prius batteries last only 4 years. You probably just need a new one.
  5. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
  6. Stevewoods
    Stevewoods Senior Member
    655
    1,070
    Seattle, WA
    Think about it. If there were a free DIY way to keep "dead" batteries working forever, don't you think we would all be using it and none of us would be buying new ones.
    A poster just started this post below a day or two ago. Up near the top is a good video on how to change out the battery...or you can pay a garage anywhere from $200-$300 to do it.
    But, you need a new battery. Period.
    08 Prius Dead. 12 v battery and spare tire under Ice | PriusChat
  7. Mendel Leisk
    40,582
    Replacing the battery is a pretty easy DIY. The most hassle free choice would be the OEM battery. There may be a "core charge", basically a small deposit, refunded when you bring them back the old one. A few suggestions:
    1. Check the voltage of the new one with a digital multimeter when you pick it up. Should be around 12.6 volt, minimum.
    2. Hook it up a smart charger, one that will cycle through a charging regimen, can be left on indefinitely, if needed, 3~4 amp range. Let it run to completion.
    3. Unhook neg cable first then positive. Install the new one in reverse order.
    4. Clean the cable end clamps, and posts on the new battery. Be careful, the dust is lead.
    The only tool you really need is a 10 mm wrench. A 10 mm ratchet wrench might be helpful, too. When tightening clamps on the new battery just don't go nuts, use firm but not heavy tightening.
    #7 Mendel Leisk, Feb 23, 2015
  8. Eclipse1701d
    Eclipse1701d Prius Enthusiast
    645
    224
    Nature coast, Florida
    Three Touring
    Dude. The battery is toast. Accept it and move on...
  9. fuzzy1
    10,335
    There is, but it is called car prowl (i.e. break into another car and steal its 12V battery), and isn't legal. And if you get caught, it is no longer free, but far more expensive than just buying a new one.
    #9 fuzzy1, Feb 23, 2015
    valde3 likes this.
  10. frodoz737
    frodoz737 Top Wrench
    4,535
    2,438
    33
    Jason, sounds like your ex just want's you to buy her new battery. She obviously doesn't know how to install one and as you said it's your son, so just do it and teach him how to while you learn how...on the Prius that is. Ex is happy, bonding time with the kid, problem solved.
    #10 frodoz737, Feb 23, 2015
  11. Jason Schwartz
    Thanks so much, everyone!
  12. Yakoma
    Yakoma Active Member
    470
    125
    sss
    DIY seems to have morphed into
    Do it MYself? No, do it YOURself!
  13. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    258
    Ocala, FL
    Sorry but she is wrong.
    The odds are overwhelming that the 8 year old battery just needs to be replaced.
    Somewhat lucky that it lasted this long.
  14. PriusGuy32
    1,417
    513
    Harrison Township, Michigan
    Well, she's your ex-wife for a reason, and apparently lack of automotive knowledge might've been part of the reason! Haha jk. I replaced the 12v in my 2007 with an OEM Toyota (yuasa) battery in under 15 minutes.
  15. Patrick Wong
    18,200
    6,493
    1. Obviously the 12V battery needs to be replaced now and that will set you back $200 or so. Just do it for your son if not for Julie.
    2. Once a new battery has been purchased, recognize that it needs to be fully-charged prior to installation. A new AGM battery should measure ~13V out of the box. If it does not, then put it on a charger overnight, set to the 4A charging position.
    3. If the new battery gets to the point where a jumpstart is required, and if you wish to save the battery at that point, it is necessary to fully-charge the battery overnight. Don't think that 20 minutes of driving is adequate for this.
    4. Julie needs to learn that it is really poor practice to get into a continued habit of having to jumpstart any car, but especially the Prius. If the jumpstart is done incorrectly you will zap the DC/DC converter within the inverter and that will set someone back four-digits to have the inverter replaced at a Toyota dealer. Instead, keep the 12V battery charged so that there is no need to jumpstart it. This may require periodically hooking up the car to a charger if the car doesn't log sufficient driving time. Maybe that is something you can do monthly, when bringing your son to and from Julie's home.
    PriusGuy32 likes this.
