  1. Jason Beauchamp
    Jason Beauchamp New Member
    25
    Lancaster, KY
    Is it normal for the 12V battery to drop too low to start after sitting for a week? Seems like it should go longer than that. 2012 model 4 with a new Toyota battery.
  2. jerrymildred
    jerrymildred Senior Member
    11,508
    14,110
    Tampa, FL
    Not normal at all. I've left ours sitting for as long a 3+ weeks while on vacation.
    Unless ... you've been making lots of short trips that don't last long enough to get the 12V charged back up. In that case, every trip will run it lower and lower till it's too low to close the relays that connect the traction battery to the rest of the car.
    And since a new battery rarely, if ever, comes with a full charge, you're starting out with a deficit.
    Jason Beauchamp likes this.
    49,446
    it is possible that the new battery was never charged properly
  4. JC91006
    16,482
    8,397
    Check to make sure you didn't leave any lights on, or leave a door/hatch ajar.
    On a brand new Toyota battery, it should last a long time before it drains to the point where the car won't start. My 2015 with a new battery was left for 4 months at a work location due to Covid. When I went to get it, it started right up.
    Jason Beauchamp and jerrymildred like this.
  5. rjparker
    rjparker Tu Humilde Sirviente
    7,964
    4,709
    Texas Hill Country
    I would check the parasitic draw. It should be around 25 ma when measured in series with the negative battery cable. We have seen 90ma - 400ma caused by obd plugins, hatch lights, aftermarket security systems, bad ecus and even the electric power steering.
    Jason Beauchamp and wheezyglider like this.
  6. Jason Beauchamp
    25
    Lancaster, KY
    Thanks for the input, I remembered I left my OBD plugged in so that would have put a draw on it.
  7. Wooward
    Wooward Junior Member
    My Ultragauge pulls ~20mAh when the car is off.
  8. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    Maybe not.
    Exactly how "new" is it ?
    Was it fully charged when new ?? (Probably don't know.)
    Have there been any other "episodes" of draining it down since it was new ?
    The battery needs to be fully charged and then tested and the charging voltage in the car needs to be tested too.
    Sometimes even "new" parts fail a lot sooner than they should.
