12v (DC to DC charger) suggestions
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Westcoastbestcoast1, Mar 9, 2022.
  1. Westcoastbestcoast1
    Westcoastbestcoast1 New Member
    Good morning,
    I am completely new to any type of forum, so hopefully I am asking these questions in an understandable way.
    I have seen many Prius conversions into a camper. I also intend to convert my 04 Prius into a similar setup.
    Is it possible to run a DC to DC charger like a Redarc (BCDC1225D) to another external lithium battery without issues? I want to run everything off of the 12v system if possible. This external battery is intended to run accessories and a sine wave inverter.
    Thank you in advance
  2. Another
    Another Senior Member
    1,802
    511
    Naples, Florida
    There are many threads on PC on the subject of inverters and also excellent videos on YouTube
    Here is one.
    If you’re going to the trouble, stick to a 1000w pure sign wave inverter like a Xantrex Prowatt 1000
    Also do not skimp on the wire gauge and install breaker
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    Regardless of what else you do, you likely will NEED a generator.......unless your power needs are REALLY small and your overnight stays are few.
    Can you arrange it so that the Prius supplies all of your power needs ?
    Yes maybe. But it likely will be a giant pain in the backside and may cost a bunch too.
    YMMV
    #3 sam spade 2, Mar 10, 2022
  4. ChapmanF
    15,614
    Have you worked out your desired power budget yet?
    Starting with that, then it's just a matter of looking at options for how to meet it.
  5. Westcoastbestcoast1
    Thank you everyone for replying.
    My intentions are to use a Redarc DC/DC charger to charge a deep cell 100 Ah lithium phosphate battery. The sine wave converter will be attached to this lithium battery not the 12v Prius battery. 100 ah is plenty for what I intend to use.
    Redarc technical team got back to me and with their product it would draw no more than 36amps/450watts while driving. The DC to DC charger will be wired to an ignition fuse. I really want to know if this draw during driving off the car will damage the battery, or any component.
    Thank you again
  6. ChapmanF
    15,614
    100 Ah tells us your energy budget (around 1300 watt hours). But your power budget (straight watts) also matters. What gear are you intending to run, using that energy at what rate?
  7. Westcoastbestcoast1
    I would like to use the battery to run a 12v fridge during work hours on the job.
    The fridge claims to use 45 watts. I would like to run this fridge for 10 hours during the day. On the off chance I need to charge my personal laptop (120 watt) I would need a small inverter.
    Do you think this will be feasible?
    Cheers
    #7 Westcoastbestcoast1, Mar 11, 2022
  8. sam spade 2
    7,035
    2,788
    2017 Prius c
    Details are important.
    Given ONLY what you put in that last post, I don't think you really need ANYTHING extra to supply the power.
    And if the purpose of the fridge is only convenience to keep drinks and food cool........a good cooler and a bag of ice should be sufficient.
    It now sounds like your "plan" is WAY overkill.
  9. ChapmanF
    15,614
    For a fridge you need to know more than one number. My 28-liter one has a label with a 6.5 amp draw at 12 volts, working out to about 80 watts. But that's the power it draws while it's running. That is one number you need to know. Your supply circuit has to be able to provide that when needed.
    A key thing with a fridge is that the only time you see it run continuously is when you first turn it on and it is coming down to temperature. Once it gets there, it cycles on and off. It then has an average power draw that reflects its running power draw times the fraction of the time that it runs. That is the figure (times ten hours) that you need to cover with your stored energy capacity. Ideally, that initial long run that pulls the fridge down to temperature can be in the house (if it's a dual-voltage fridge) or in the car in READY, so you aren't spending your stored energy budget on that.
    Depending on who made your fridge, it might come with graphs sort of like these. (These are for an Engel MT27F.)
    You'll notice there are three graphs, for three different surrounding temperatures. In all three, the temperature inside the fridge is eventually being held around 4 or 5 ℃, but at the higher surrounding temps it takes longer to get there, and it runs for more of the time in order to stay there. In this example, at 25 ℃ surrounding, it only needs to run about a quarter of the time, corresponding to about 20 'average' watts. At 45 ℃ surrounding, it is running more like four fifths of the time, so closer to 65 average watts.
    If the thing will be inside your car, then the "surrounding" temperature really means the temperature inside the car, which can be a lot higher than outdoors if the car is unattended in the sun.
    You can see some funny notation when you're looking at fridge specs. For example, in the graphs above, you can see the average current draw summarized as "1.46 Ah/Hr" under the middle graph. An "amp hour per hour" is just an amp, a "watt hour per hour" is just a watt, but the fridge folks like to spell it that weird way to remind you that it's the average holding-temperature figure, and not the rated amp or watt figure for when it actually runs.
    You'll also notice those summary Ah/Hr or Wh/Hr figures work out to even lower power than we guessed by just multiplying rated running power by the fractional run time. Multiplying amps by 12 to get watts, we see (for that Engel) about 8 watts (or "Wh/Hr") in 25 ℃ surrounding, 18 watts at 35 ℃ surrounding, 27 watts at 45 ℃. That's because, once down to temperature, the compressor isn't just running less of the time, but also at a lower pressure.
    So you can see that, if you had a similar fridge, you would need to give it a supply with about 6.5 amp (~ 80 watt) capacity, but you would also expect it to be drawing only around 30 watts steady-state, even in a fairly hot car. For ten hours of that, you would need 300 watt hours of capacity.
    When you add your laptop charger, that's an extra 120 watts, but only for as long as it takes to charge the laptop battery. Probably the easiest way to figure that energy budget is to look for a watt-hour spec on your laptop battery. That's how much energy you'd need to put a full charge on it from empty (if batteries were perfect. They're not, so multiply it by about 1.5).
    All the fridge discussion above pretty much assumes a compressor, refrigerant-cycle fridge. Some less expensive options just use a thermoelectric cooler, and are a lot less efficient. One of those probably will be drawing 45 or 50 watts or so, and drawing it pretty much continuously.
    Another likes this.
  10. Westcoastbestcoast1
    ChatmanF thank you so much for your brilliant explanation and taking the time. The fridge I was looking at does not appear to be as quality as the Engel brand nor does it provide the necessary data as the Engel brand does. So I have decided to order an Engel brand with similar specifications. Being able to have a dual power source and getting the temperature low prior to putting in the car is a great idea.
    (Thank you for clarifying that it is simply just a watt)
    So with a 100ah battery (~1300watt hours) -
    - Fridge at 30 watts for 10 hours
    - laptop at 120 watts for 3 hours
    I would have a combined total of 660 watt hours.
    This appears to be sufficient enough capacity for the 2nd battery. This is perfect in case I need to use a little extra.
    So when all said and done I'll have to post how the project went with a couple of photos.
    Cheers
  11. ChapmanF
    15,614
    Laptop at 120 watts for 3 hours sounds like quite a lot for a charge, 360 watt hours. Even using the "overstate by 1.5 to account for charging losses", that would be a 240 watt hour battery in that laptop.
    That would be a big battery. If you were flying on an airplane, for example, the normal limit of 100 watt hours is supposed to "allow for nearly all types of lithium batteries used by the average person in their electronic devices." You would need the airline's approval to bring on board anything between 100 and 160 watt hours, which would be considered to cover "larger after-market extended-life laptop computer batteries and some larger batteries used in professional audio/visual equipment."
    Now, if you weren't thinking only to leave the laptop charging there, but to actively use it in the car while powered by the adapter, then I could see you using 120 watts for three hours of use, if it's a high-end laptop and you're pushing it hard.
  12. Another
    1,802
    511
    Naples, Florida
    The holy grail of Prius backup power.
    1000w inverter and two of these in parallel
    https://www.costco.com/lion-energy-safari-ut1300-2-pack.product.100663833.html
    only $1400 plus inverter!
    Features:
    • 12.8V, 105Ah, 1344Wh
    • Can be Used in either Series or Parallel Configuration
    • 150A Continuous Draw, 100A Charge
    • Lithium Iron Phosphate Battery Chemistry for Long Life and Reliable Energy Storage
    • 3,500 Full Depth of Discharge Lifecycles
