  1. channing watson
    channing watson Junior Member
    22
    columbus
    I just got done repairing a reverse polarity-ish jump. (I literally tripped over the cables and they fell in such a way as to cause a reverse polarity arc..yeah, that's my luck). The car was being jumped because the 12v had randomly died. The car was jumped at the front jump location. Blew the DC-DC fusible link and the 120 amp fuse at the battery (plus a few others)
    I fully charged the 12v battery with an imax b6. I get 14v at the terminal in ready mode. I have taken 3 short trips in the car today and the resting voltage of the battery is now at 10.5v
    I have no parasitic draw (.06 amps) when the car is off. The battery is less than 6 months old and still under warranty.
    Any idea beyond a bad battery?
  2. SFO
    SFO Senior Member
    5,297
    4,237
    Northern California
    Any lights displayed or DTCs thrown?
    channing watson likes this.
  3. Patrick Wong
    18,200
    6,474
    Since the car starts, you successfully replaced the 120A MAIN fuse.
    Since you measure 14V when the Prius is READY, you successfully repaired the 100A DC/DC fusible link, and the DC/DC converter was not damaged.
    How much parasitic current draw do you measure? Normal would be around 0.02A.
    How much time was required for the battery to register fully charged by your charger?
    It does sound like the 12V battery needs to be replaced.
    Mendel Leisk and channing watson like this.
  4. Jmack111
    Jmack111 Member
    370
    78
    Tacoma wa
    Either the car is not charging or you have a bad battery check the ground from the inverter to the chassis to the negative terminal make sure they all match 0 probably an open ground. So you have voltage and no current draw open ground
  5. channing watson
    22
    columbus
    Nope. Nothing showing.
  6. AndrewR
    AndrewR Junior Member
    SF Bay area
    2014 Prius c
    Good question. Try a certified toyota mechanic
  7. SFO
    SFO Senior Member
    5,297
    4,237
    Northern California
    How many hours per week is the vehicle generally in use?
  8. channing watson
    22
    columbus
    .06 amps was the max I got.
    it took about 14 hours to get it fully charged at 5 amps. It had tapered down to .2 amps when I pulled it. ~19k MAH according to the charger, it was at 12.8 resting voltage about an hour after taking it off the charger
  9. Jmack111
    Jmack111 Member
    370
    78
    Tacoma wa
    When the battery charged up you have dash lights and the screens on right
  10. channing watson
    22
    columbus
    2 to 6 hours a day usually, I deliver for a living. It sits for a few days here and there
  11. channing watson
    22
    columbus
    Yep, runs fine, everything is normal before it dies. drove it 3x today about 30 minutes a trip
  12. Patrick Wong
    18,200
    6,474
    When the Prius has all doors, hatch and hood locked, the current draw should be 0.02A. 0.06A is a little high but I don't know if that is because of measurement inaccuracy in your meter or if the car actually has a small problem.
    The 14 hour charging time and the resting voltage both seem normal.
    So your charger indicated that it put 19Ah into the battery? That is interesting. The battery may not fail a test if returned to your supplier.
  13. bisco
    49,492
    what makes you think it is not a bad 12v?
    how old is it?
    edthefox5 likes this.
  14. channing watson
    22
    columbus
    it very well could be, just wondering if anyone had any other ideas. It took a charge fairly normally, not that it means anything. I bought it in July of last year. It's a bosch group 25.
  15. channing watson
    22
    columbus
    Yeah, 19AH give or take a little. It was at 8.2v when I hooked it up after sitting over night, well past the no-no zone.
  16. bisco
    49,492
    new enough, but maybe you fried it. charge it up before you aren't going to use it for a few days. then unsure the voltage, then turn the headlights on and measure voltage drop over time
  17. Jmack111
    Jmack111 Member
    370
    78
    Tacoma wa
    How much current do you have with the car on like it's charging the battery
  18. channing watson
    22
    columbus
    not sure, I would have to borrow a better meter or an amp clamp to measure it directly.
  19. Jmack111
    Jmack111 Member
    370
    78
    Tacoma wa
    That'll tell you whether or not you're actually pulling any current into the battery and if you are you have a bad battery
  20. SFO
    SFO Senior Member
    5,297
    4,237
    Northern California
    That is plenty of 'Ready' time, if that battery known to be decent.
