12v in the front
Discussion in 'Gen 4 Prius Main Forum' started by MikeV, Aug 15, 2023.
  1. MikeV
    MikeV Junior Member
    95
    philadelphia
    i see in the gen 4 the 12v was put under the hood. is that now a "standard" battery do they need replaced more often like in conventional vehicles.
  2. JC91006
    16,501
    8,413
    it'll probably be very similar to the sealed AGM units in the older generations. But the engine heat might be a bit more harmful to their longevity overall
  3. sylvaing
    sylvaing Senior Member
    1,167
    490
    Does the vehicle warns you in advance that the 12V needs to be changed soon? If not, what's the symptoms to look for (beside a car not turning on)?
  4. JC91006
    16,501
    8,413
    There is usually not a lot of warning, an indicator for me to change a battery is usually when a lot of corrosion/acid materials start forming on the battery terminals.. If you're worried about battery failure, you should change it every 5 years or so. Some may even fail before that time, and some will last longer. But that is usually a good timeframe for a Prius 12v battery
    sylvaing likes this.
  5. bisco
    49,844
    it is not a 'standard battery' in terms of size, it is still difficult to find and expensive.
    it is a conventional battery though.
  6. MikeV
    MikeV Junior Member
    95
    philadelphia
    shoot thats what i thought .
  7. JohnPrius3005
    JohnPrius3005 Active Member
    422
    232
    California and Hawaii
    Get a charger and digital voltmeter and charge the bat whenever you won’t use the car for a while. A good charger will give you some indication when the battery is shot.
  8. FuelMiser
    FuelMiser Senior Member
    1,307
    892
    Monument, CO
    Yes, it a standard, wet cell lead-acid battery. Not AGM. I don't believe there's any difference in lifespan. I'm still using the original battery in my 2016 Hybrid, now 7 years old. Here's the spec,
  9. Doug McC
    Doug McC Senior Member
    1,011
    381
    Midwest
    2022 Prius
    As far as a warning that it is going to fail you could buy a simple battery tester (preferably one that indicates Internal Resistance) and spend about 2 minutes every once in awhile to test it.
  10. sylvaing
    1,167
    490
    The car should have that logic built-in and warn you when it detects the 12V battery needs to be replaced soon.
  11. bisco
    49,844
    that would be a great feature!
