12V mod?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by exmetrodriver, Jul 2, 2015.
  1. exmetrodriver
    exmetrodriver Member
    124
    16
    Puget sound, Wa.
    I'm looking to get power out of my 12V outlet with the car off. Does anyone have a write up on how this is done?
  2. xliderider
    xliderider Senior Member
    8,056
    3,224
    Honolulu, HI
    The Prius auxiliary battery has very little reserve. It's probably not a good idea to tap too much out of it without the Prius in Ready mode.
  3. cproaudio
    cproaudio Speedlock Overrider
    2,401
    760
    CA
    Easiest way is the fuse box mod. You'll need a mini fuse tap like this
    Plug the fuse tap into a fuse slot with constant power and plug the red wire into the power outlet fuse leg that goes to the cigarette lighter plug. It is totally reversible to OEM.
