12v, no dash lights o rock backup cam
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by DaVincian888, Apr 18, 2021.
Tags:
  1. DaVincian888
    DaVincian888 Junior Member
    Four Touring
    Greetings All.
    I currently own a 2007 Prius with less than 48k miles on it, have only replaced the 12v battery 1x at Battery Plus until last week where after replacing it at AutoZone, my dash lights and reverse camera have stopped working.
    Is it a fuse issues or should I have gotten the 12v from BatteryPlus again instead of AutoZone?
    Please help, thanks!
  2. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    You do realize that it is impossible for anybody to give you a precise answer without actually being there.......right ??
    Does everything else work......does it go into ready mode and drive OK ?
    While it is possible that your new battery is bad, it is highly unlikely if the car drives OK.
    You might want to disconnect the battery again for a few minutes and re-connect it.
    Might also want to have your new battery tested.
    But likely that it is just a coincidence.
    Where you get a battery from makes no difference.
    If it produces the proper power, it is fine.
