12v OEM battery cost is it worth it?
Discussion in 'Gen 4 Prius Main Forum' started by Jdpl76, Mar 10, 2024.
Tags:
  1. Jdpl76
    Jdpl76 Junior Member
    16
    Artesia, California
    I just wanted to post my experience about the type and cost of the OEM battery and purchasing one. After a couple of 12v low and cannot shift warnings I tested and found that I needed a new battery. The date was 6/19 on my battery and so if it was supposed to last 84 months it definitely went out early.
    The battery is called an H4 and the cost was $266.41+tax at the dealer not installed. The part# is 00544-H4052-470 TRUESTART 199B. It comes with a 7 year warrany which is 2 years and pro-rated for the remainder. I could not make a claim because my car was bought used. If your car is new and still under warrany then you would get pro-rated.
    I've ready here about batteries cosing just $30-40 more than an OEM. I would say it is more like $100 more than say a Duralast. I think its probably going to be worth it but I will have to see when I get there. I've never seen a battery last 7 years, more like 3 but this one lasted 5 so thats not bad.
    I hope this info helps the next person.
  2. texasdiver
    texasdiver Member
    68
    114
    Vancouver WA
    Four Touring
    I replaced mine about 2 years ago. I just went to AutoZone and bought the correct size replacement. Which is something of an odd size and they didn't have it in stock at Costco. I had to call around.
    Otherwise it works fine. 12 volt lead acid batteries are old generic technology. There is nothing special about OEM batteries as long as what you buy fits into the space and won't fly around.
    52,351
    5 years is actually better than average in a warm climate.
    I’ve had good luck with the oem’s, usually 7-8 years, but it’s cooler here in the northeast, and keep in mind it depends on how much you drive it.
    The longer it sits between drives, the more quickly it degrades
  4. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    Walmart sells the EverStart MAXX, Group Size H4, also labeled 140R, for $159.84. I've installed two of them on my 2016 and my sister's 2017. Completely satisfied.
    Brian1954 likes this.
  5. Robert21PrimeLTD
    88
    42
    Nashville
    What about a AGM (absorbent glass mat) battery? Since I drive mostly in traction mode would a AGM battery make sense?
