12v outlet not working...
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by hellochicken, Jul 16, 2015.
  1. hellochicken
    hellochicken Junior Member
    31
    los angeles
    hey yall..
    so I've had my 12" prius for almost 7 weeks now, and today my 12v outlet in the armrest stopped working. I'm wondering if any of yall had similar issues, and I'm curious what yall had to do to get it fixed. could it be just a fuse issue? if so, yall know where and how I can go about that? I guess I can just walk over to the car and pull out the manual... but then I wouldn't get to socialize...
    anyways, thanks.
  2. DavidA
    2,328
    1,812
    Chicago western burbs
    Was the car off or on?
  3. hellochicken
    31
    los angeles
    the car was on... the 12v plug under the radio still works.
    49,474
    you have a 12" prius?:eek::p
  5. mrbigh
    3,686
    699
    Long Island, NY
    blown fuse....
  6. bisco
    49,474
    under hood or dash?
  7. RRxing
    RRxing Senior Member
    2,520
    1,791
    NEPA
    See attached. Either fuse #1 or #3, under the dash...
  8. qdllc
    qdllc Senior Member
    1,370
    399
    He's bragging. My "prius" is only 5.5 inches on a good day. :sick::ROFLMAO::whistle:
  9. hellochicken
    31
    los angeles
    my Prius is the size of what you imagine a chicken Prius would be....
    anyways, thanks yall! blown fuse.
  10. Metz
    Metz New Member
    Fairfax, VA
    I have a similar problem and it's not the fuse. My outlet under the radio isn't working, but everything else does, including the USB. I checked the two 15A fuses for cigarette lighter and outlet, both are good. Everything else in the vehicle works properly.
    I had a similar problem on my 2006 Sequoia and it was a breaker system. I had to pull a particular fuse, leave it out for 10 sec, then the breaker reset and I could replace the fuse and it worked properly. In that case the fuse for the outlet was also good.
    Do you know if the Pruis uses a similar system?
