12v Power outlet
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Pat Down Under, Apr 1, 2007.
  1. Pat Down Under
    Pat Down Under New Member
    On the 2004 Prius modle sold in Australia we only get the one 12v outlet in the console.
    I need to put an aditional outlet in my vehicle on the drivers side ( yes righthand side )
    I have invesigated under the dash, can anyone give some advise to where to start
    e.g Connection point to source to power from, I will be using it to power a portable navigator.
    Pat.
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    Are you certain you don't have 2 outlets in the front? One on the kick panel b/w the driver and passenger footwell and one inside the center arm rest?
  3. Pat Down Under
    Have searched to vehicle iv conduct another tomorrow morning.
    Thanks for the tip.
    Pat
    quote name='efusco' date='Apr 2 2007, 01:08 PM' post='416255']
    [/quote]
  4. Bill Merchant
    Bill Merchant absit invidia
    4,096
    81
    Pat, in the US model the one near the passenger's knee has a black plastic cover with sort of a pinch handle over it.
  5. Zamboni68
    Zamboni68 New Member
    Lancaster, Ohio, USA
    [attachmentid=7377][attachmentid=7378]
    I installed two (2) 12V outlets in the center hump plastic after adding a "tap" to the fuse block. I don't like splicing into existing circuits, so I added a seperate fused circuit for my mods. TOtal cost was US$20 for the two outlets, the "tap" circuit.
  6. Robert Fisher
    Robert Fisher New Member
    53
    Shasta Lake, California
    [attachmentid=7383]Here is a suggestion.
  7. adam1991
    adam1991 New Member
    218
    I have this; it's like it was custom designed for the Prius:
    http://www.bellautomotive.com/asp/product_...ls.asp?id=25209
    I found it at a local Target. It comes with some Velcro squares; I simply stuck the hook portions to the bottom of this unit, and it sticks like glue to the carpet right on the center hump. It's just the right size and everything.
    [attachmentid=7386]
  8. Skwyre7
    Skwyre7 What's the catch?
    2,332
    Richmond, Virginia
    I use that one too (the one from Target). It works nicely for what I need.
