12v power port not working
Discussion in 'Gen 3 Prius Technical Discussion' started by Shank, Sep 5, 2022.
  1. Shank
    Shank Junior Member
    Vermont
    The dealer did some work on my brakes and now the 12v power outlet under the armrest isn't working. I replaced both 15amp fuses labeled power/cig and still doesn't work. I don't see how brake work could have had any impact on the outlet unless something got fried when they disconnected the 12v battery.
    What else can I check to troubleshoot this?
    52,713
    see if there ispower at the fuses. car is on, correct?
  3. ASRDogman
    ASRDogman Senior Member
    7,993
    4,056
    Did you contact the dealer and ask them????
    That should have been the first thing you did, after checking the fuses....because that's simple.
  4. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    o_O
