12v Power Terminal Cover (fuse box)
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by lengz, Feb 19, 2017.
  1. lengz
    lengz New Member
    United States
    I'm having trouble removing the little cap that covers the 12v power terminal under the engine bay fuse box. Am I suppose to pinch those two tabs together as depicted in my picture? I've tried, but it doesn't look like it's budging. Does anyone know how to take this off?
  2. tankyuong
    tankyuong Senior Member
    1,555
    660
    Central MO
    Lift it to one side
  3. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    It's been a while since I opened ours up, but if memory serves me you need to use a small flathead screwdriver to release the catches/tabs.
  4. saltdiscus
    saltdiscus Member
    198
    89
    US
    I had same problem trying to remove for my his light project.I almost drill it out of frustration then paid professional to install it and I don't know how they removed it .I am also interested for solution.
  5. xliderider
    7,869
    3,116
    Honolulu, HI
    Here's a picture of it opened up, but I don't know if it'll help:
    FYI, just use the two open terminals at the back of the fuse box for +12v power, the ones with the two red wires going to them in my picture above.
    saltdiscus likes this.
  6. Mendel Leisk
    38,732
    I was hooking up a charger (which I do periodically, our car will often sit for several days), and thought I'd try taking that cap off. Tried pinching the two tangs, and spreading them. Also tried pushing the middle tab. None of the above helped.
    I'd kinda like to hook up a quick connect for my charger, so I don't have to pull the fuse box cap off, was wonder what was under there. Is it actually a good point to hook up 12 volt, say for a charger positive lead?
    #6 Mendel Leisk, Feb 20, 2017
  7. jerrymildred
    jerrymildred Senior Member
    11,511
    14,113
    Tampa, FL
    Are you talking about the red cap over the positive terminal under the hood? On my PiP, I just pry the catch a little to release it and swing it up on its hinge end. Here's a screen shot from the manual.
  8. Mendel Leisk
    38,732
    No, that was my first thought too, reading the first post. If you look at the attached pic in that post, it's the piece with the two red arrows. Actually, they're probably indicating the solution, if I could just understand it.
    Yeah I use the jumpstart point for my charger, but have a quick connect options, would save wear-and-tear popping the fuse box lid off so frequently.
    WilDavis and jerrymildred like this.
  9. xliderider
    7,869
    3,116
    Honolulu, HI
    Mendel, that 10mm bolt under the cover is an always hot +12v connection to the positive terminal on the auxiliary battery. For all intents and purposes, treat it as if it is the positive battery terminal. It would be highly advisable to disconnect the ground strap to the body at the auxiliary battery in the hatch before you start wrenching on it. ;)
    So yes, it would be a good place to mount the quick connect for your battery charger, if it has a ring terminal.
    WilDavis, orlywon and Mendel Leisk like this.
  10. jerrymildred
    11,511
    14,113
    Tampa, FL
    Ah! Now I see it. Yeah, I tried for a couple minutes to get that off and gave up. LOL!
    edthefox5 likes this.
  11. saltdiscus
    saltdiscus Member
    198
    89
    US
  12. Mendel Leisk
    38,732
    Same story here. There's two tabs in the middle of the top, two more, on either side, and a kinda complicated looking hinge down the side. I can get raised about 1/8", and it's got some play but not going any further. Trying to be careful too...
    My back told me to pack it in, go in.
  13. Mendel Leisk
    38,732
  14. WilDavis
    WilDavis Senior Member
    2,492
    2,153
    49
    …that's exactly what I did on my 2009 Gen II, makes it really easy to connect the battery tender! I used one of the other fasteners for the ground-point.
  15. Mendel Leisk
    38,732
    @xliderider If there's any more ideas you can share re getting that black cap off, don't hold back lol.
    By my count there's four release tabs on the top, and down the side a full length hinge, and a similar something-or-other.
    I've spent an hour of concerted effort, trying to get it off. With the same amount of success as some puzzles my son got me for Christmas...
  16. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,476
    1,552
    Bay Area
    Are you guys trying to open this part up?
    Raytheeagle and Mendel Leisk like this.
  17. xliderider
    7,869
    3,116
    Honolulu, HI
  18. NutzAboutBolts
    1,476
    1,552
    Bay Area
    You need to get a small screw driver and press outward on these 2 tabs. It's held on by the fuse box case, so you can only lift it and turn it to the side to reveal the terminal.
  19. Mendel Leisk
    38,732
    Thanks, excellent pics! I can get it to lift, maybe 1/8". Pushing at the tabs and lifting at same time. So lift as much as possible and then rotate?
  20. NutzAboutBolts
    1,476
    1,552
    Bay Area
    It shouldn't give you a hard time if you pressed out on the two outter tabs. It's clipped on basically and there's a rotating shaft on the corner that attaches to the fuse box case
