12v Source in Headliner/roof area?
Discussion in 'Prius c Accessories and Modifications' started by scrull, Jan 3, 2015.
  1. scrull
    scrull Junior Member
    36
    24
    Charlotte, North Carolina
    Hey guys, i'm setting up a Valentine V1 near the top of my windshield and it requires a 12v source for power. Currently, I've routed a wire up along the driver-side weatherstripping and headliner. This works fairly well but I was wondering if there was a 12v source in the headliner area I could T-tap for a more streamlined setup. I was thinking the dome lights, but those are all controlled by switches and door relays. Does anyone know of a power source that is constant 12v or switched on by battery in that area?
  2. djdawn
    djdawn Active Member
    255
    116
    Escondido, CA
    2014 Prius c
    Try testing the 12v line going into the dome lights. I'm under the impression that the door switches work as a ground interrupt, not actually acting on the 12v line
    orenji likes this.
  3. scrull
    36
    24
    That's a good point.
  4. GregP507
    GregP507 Senior Member
    3,002
    480
    If you've changed-out the incandescent bulbs for LEDs, you're probably using less current, therefore a bit of surplus capacity should be available.
