12V starter battery drained - risks of charging it?
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Jan M, Mar 6, 2019.
  1. Jan M
    Jan M New Member
    Danbury
    I
    My wife drove her 2013 Prius C last night and parked it in a garage .... leaving it there running. Our teen age son noticed 4 hrs earlier that car is running in a garage ... and turned it off but leaving the key in ignition.
    Earlier this morning dashboard lights and stats (last trip time length, miles, cost of gas etc working but unable to start, crank the engine.
    Called dealerhip: get it towed there they advised.
    Looked up bunch of YouTube clips some of them by dealers.
    Using smal DieHard charger (connected plus to red port in fuse box on driver side and negative as recommended on videos and by Toyota dealer video included)
    But after about 2 hours of charging with internal lights at ceiling lighting up when getting in a car and only check engine icon lightened I am unable to sense any juice in the battery. Car has 55000 miles, almost 6 yrs old, garaged in our CT weather.
    What to do?
  2. Jan M
    Jan M New Member
    Danbury
    I
    Charger went from initial yellow light (charging) to pulsating green "fully charged" but that is not certainly the case
    52,395
    welcome!
    couple of issues. prius battery is agm. you need an appropriate smart charger to charge it properly.
    even then, if it has internal damage, it will have to be replaced. 6 years is a pretty good run.
  4. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    Try disconnecting the battery for 30 mins and then trying again.
  5. Leadfoot J. McCoalroller
    8,149
    7,653
    Pennsylvania
    2018 Prius c
    Did it run out of gas?
    If the car still has fuel, then the 12v battery may be too far gone for a charge to help.
    If the car did run out of gas, you may have bigger problems.
  6. Mendel Leisk
    41,911
    Check the battery voltage for starters, with a digital display multimeter, and post. Due to charging it'll likely be reading higher than "real" voltage, but you've got to start somewhere. Check it at the jump point, and directly at the posts if you can. I believe it's tough to get to the battery in the c?
    Doug McC and Jim Bob Khooter like this.
  7. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Classic symptoms of a worn out battery.
    6 years is a bit past their normal life.
    Get a new battery. Be sure it is charged before installing.
    If you have a Pep Boys auto parts store nearby, they seem to come recommended for Prius batteries.
    And a dealer will be a bit more expensive.
    P.S. In a hybrid vehicle, the 12 V battery does NOT turn the starter like with a conventional car. It only boots up computers but the end result is about the same when it goes dead.
  8. sam spade 2
    7,035
    2,804
    2017 Prius c
    No you don't. Any "good" charger will work just fine.
    It might only charge it to 95% capacity instead of 100 but in most applications, that is not an important difference.
    Doug McC likes this.
  9. Mendel Leisk
    41,911
    The difference in chargers, as far as I know, is an AGM capable charger will be able to charge at slightly higher voltage rating. My older CTEK 3.3 doesn't have that, while my newer CTEK 4.3 does. Either will charge fine, just the 4.3 is maybe a bit more effective/faster.
  10. bisco
    52,395
    put a volt meter on her, and see what comes back
  11. Ellis Fereday
    Ellis Fereday Junior Member
    26
    when connecting the harness, do you connect the negative ring to the battery connector or to the bolt that is connected to the car on the negative side? thank you
    #11 Ellis Fereday, Oct 14, 2022
  12. Doug McC
    Doug McC Senior Member
    1,082
    421
    Midwest
    2022 Prius
    Assuming that the battery was nearly completely drained and that your charger wasn’t putting out an extremely high charge rate: 2 hours of charging will not give the battery a significant enough charge to do much of anything. Charge it overnight, retry to start the car.
    If it is still “dead” then put a multimeter on the battery terminals and if you get a reading above ~12.2 volts then you need bite the bullet and have it towed to the dealer. Someone who actually knows what they’re doing needs to look at it.
    If less than ~11.9 volts, then you could try replacing it with the same type of battery Toyota put in it originally and see if that works. If not, then, once again, you need to have it towed to the dealer.
