'13 C - need some tips on a DIY engine replacement (aka how do you get this darn engine in)
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by madmax21, Mar 26, 2021.
  1. madmax21
    madmax21 Junior Member
    16
    Minneapolis
    Hey all, looking for some input. I had a snapped headbolt in my old engine and just said f-it instead of trying to drill it out I went for a new used engine.
    I've gotten the old engine out, that wasn't too bad, tight-ish fit on the way out but minimal jiggling it came out the top. Water pump was still on but the head was off and the timing chain cover was off too.
    Now here's the pickle....the new engine is a junkyard one with pretty much EVERYTHING on it- super good deal 350 for a 40k engine when mine was at 140k plus legitimately everything attached sans wiring. But now trying to lower it in, it's not dropping in, the flywheel is ever so slightly too big and it's catching on the bellhousing when the opposite side is bumping the frame rails. I've jacked the transmission up and down to try and get it to accept the engine but it's still too tight. I've already got the external flywheel off the engine to give more room but don't want to take it apart too much if I don't have to.
    My current two ideas are to pull off the water pump to give slightly more front to back motion, otherwise perhaps pull off the dogbone transmission mount and try to get more movement out of the bellhousing to sneak the flywheel down in it.
    Anyone replace an engine in their C and can comment?
    Any help is appreciated!!
  2. PriusCamper
    PriusCamper Senior Member
    13,018
    5,290
    Pacific Northwest, USA
    Haven't seen much for engine swap posts for Prius C / Prius Aqua on here. But maybe if you did some searches on You Tube?
  3. madmax21
    16
    Minneapolis
    I definitely have, the one that's there they take out the subframe and the transmission, I want to avoid that. Oh also they drop the car on the engine and transmission instead of going through the top...... there's a number of gen ii and gen iii swaps on YT and those are all just engine removal w/o the tranny coming out
  4. PriusCamper
    13,018
    5,290
    Well, if you got it out... Seems to make sense that you can get it back in one way or another. Of course us DIY folks pull engine from the top and auto shops with lifts pull engines from below so we're kinda on our own. But most important, I hope you figure it out and post it so it helps others on here.
    G-Squared likes this.
  5. Mark343
    Mark343 New Member
    Any update to this thread? Currently stuck in the same boat. Did you ever get it installed
