130k and mostly only oil changes so far. now what maintence
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by zmre2b, May 20, 2011.
  1. zmre2b
    zmre2b Junior Member
    70
    US
    From the various other threads with lots of different, and sometimes conflicting info, it seems that I should do the following for my 130k, no problems so far 2005 prius:
    * Inverter pump replacement under recall: (LSC) A0N - 2004 through Certain 2007 Model Year Prius Vehicles - Electric Hyrbid Water Pump Replacement Code: A0N Memo
    * Steering Shaft replacement under recall SPECIAL SERVICE CAMPAIGN (SSC) – 60C (SAFETY RECALL) (2004 THROUGH EARLY 2006 STEERING INTERMEDIATE SHAFT REPLACEMENT). SSC – 60C
    * replace spark plugs
    * Replace engine thermostat
    * Replace PCV valve
    * Brake flush(do NOT leave air in the brake system, or damage actuator or solenoid valves. If it is risky -- don't do it. The brakes are fine.)
    * transaxle fluid drain and fill, no flush). Do not use wrong fluid or fill incorrectly. 75
    * Oil change
    * Tire rotation (put rear on front)
    * engine air filter
    * cabin air filter
    * Check drive belt
    * check engine coolant pump (i.e., weeping at the shaft seal)
    * Check front struts and rear shocks; maybe replace w/ alignment
    I would also replace the engine coolant and 12V battery except those were replaced a year ago.
    Anything else I should do at 130k?
  2. Patrick Wong
    18,200
    6,493
    I would replace the serpentine drive belt (vs. checking it). That part is inexpensive and there is no doubt that the inside is full of cracks after 130K miles.
    I would pass on the fuel injector cleaning unless the engine has driveability issues.
    If the front struts and rear shocks are original equipment, they very likely need to be replaced now.
    The front brake pad and rotor condition also should be inspected.
  3. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,517
    38
    Santa Fe, NM
    No brake flush.
    No thermostat replace.
    Combo spark plugs+air filter with MAF and throttle body cleaning.
  4. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    The engine thermostat in my car leads a sedentary life. I wonder if that means longer or shorter lifespan ?
  5. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
  6. jdenenberg
    jdenenberg EE Professor
    3,926
    1,923
    Trumbull, CT
    2020 Prius
    LE AWD-e
    I replaced the thermostat preemptively at 150k miles when I did the second coolant change (along with replacing both water pumps and the serpentine belt). I guess I'm just an old fashion guy.
    JeffD
  7. SageBrush
    11,627
    2,533
    Southwest Colorado
    Hi Jeff,
    That is my plan too, if the pump or thermostat does not break first.
  8. Mendel Leisk
    40,586
    Just thinking: we had a coolant thermostat go bad on a previous Honda Accord. The tip off for me was seeing the coolant temperature gauge down at the bottom after an extended freeway drive: started thinking why that should be happening, researched it, found reports of stuck open thermostats being the cause.
    They're mechanical components, with a rubber gasket that can harden and/or fray. When changing it I tried suspending both the old and new one in a pot of water on the heat, and watched their performance.
    The old one was never fully shut, even when cold(due to fraying of the gasket). This meant there was always some coolant flowing into the radiator, even when the car was cold. It also opened sooner and closed later, again leading to over-cooling.
    Now with the Prius, if you have a thermostat failure of this sort I guess you're SOL unless you have a ScanGauge (or similar): no coolant temp gauge. Unless maybe the computer will notice overcooling anomolies and light up a warning.
  9. JerryCS
    JerryCS Prius camper with trailer hitch
    77
    Elk Rapids, MI
    Thanks for the extended maint schedule. I don't find any mention of struts in it. Anyone have a recommended interval for replacement? Has anyone replaced them other than to modify the suspension?
    Jerry
  10. Patrick Wong
    18,200
    6,493
    If you want to maintain the suspension in top condition, I would say that the front struts and rear shocks should be replaced at ~60K mile intervals. However this is a costly job and I doubt that many owners will be willing to have that work done so frequently.
    I have posted on how to replace both the front struts and rear shocks in this forum.
