'14 Prius with 15 Year Inverter Warranty Or '15 with 'fixed' inverter & no warranty?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Haschwalt, Aug 10, 2019.
  1. Haschwalt
    Haschwalt Member
    110
    31
    New York
    Also, https://attachments.priuschat.com/attachment-files/2019/04/165269_T-SB-0169-16.pdf
    The '14 has the changed piston but not the ring but has a 15 year extended warranty on inverter.
    The '15 has both the changed piston and ring but no 15 year extended warranty on inverter.
    The piston & ring is presumably a fix by Toyota for the oil burning issue, but is less of an issue vs. the inverter imo.
    This implies the '15 has fixed the inverter issue, but it's not a guarantee unless someone an speak on whether or not the '15' inverter fixes this issue.
    The bigger issue is the inverter because tens of thousands of Priuses have had them fail Source: Toyota Prius Stalling Problems Continue - Details of Dealer Lawsuit -
    Three recalls to fix more than 800,000 cars have allegedly not remedied tens of thousands of reported failures ~ 5-10% failure rate. July 2019
  2. StarCaller
    StarCaller Senior Member
    1,246
    697
    Cedar Crest, NM, USA
    Haschwalt likes this.
    49,482
    because used inverters are a hundred bucks, and easy install, i would go with the 15, since new piston rings are a real pain
    Patrick Wong and Haschwalt like this.
  4. Haschwalt
    Haschwalt Member
    110
    31
    New York
    Ah, I was under the impression the inverter was something like $3k. But only $150? Well, back to searching nationally for a '15 then lol.
  5. bisco
    49,482
    3k at your local stealership :p
