'14 v, 216K, engine rattle upon startup
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by RomaniGypsy, Jul 14, 2019.
  1. RomaniGypsy
    RomaniGypsy Junior Member
    34
    22
    Conneaut, OH
    2014 Prius v wagon
    I've been cruising the threads and may have zeroed in on the cause of this, but I'd prefer to run my specific situation by everyone and see what they say.
    This car has been awesome. I'm at just under 216,000 miles and haven't had to do anything to it except the recommended maintenance, tires, brakes, and a rear license plate light.
    For the last 25,000 miles or so, the engine (ICE) has been rattling occasionally upon startup. I first noticed it happening after I'd been cruising on battery power for a while and the battery gauge had gotten down to two bars. It has always been an intermittent thing and I discovered that it would stop if I pushed the accelerator in harder to make the ICE work harder.
    These days, sometimes it happens upon startup at rest, and it doesn't seem to matter how charged the traction battery is. I'd say that it happens more commonly after the car has been sitting for a bit, but not so much after it's been sitting overnight. It'll last for several seconds when it happens, and it feels like the ICE is going to shake itself loose from its mounts. I was able to pop the hood one time recently before it stopped, and I saw the ICE wobbling from front to back, and it seemed that the accompanying sound was coming mostly from the right side.
    I am low on coolant; the overflow tank is almost empty. Sometimes I have been smelling coolant after turning off the engine and getting out around the car, but I've never seen dribbles. The "check engine" light has never come on.
    I've had it since new, did dealership servicing for the first 25,000 miles with Toyota Care, then switched to mostly local-mechanic servicing except for the big one at around 110,000 miles. I know I knocked out two major servicings at once right there - I know that one was for 120,000 miles and the other was for either 100,000 or 110,000. Since 196,000, each servicing has been at the dealership because my local shop went out of business and I haven't chosen another local shop... plus the dealership does free oil changes for any Toyota or Lexus at 200,000 miles or more, so I can't argue with that. I mentioned the engine rattling issue at 196,000 miles and they said nothing about it.
    Recently I've also noticed that when the ICE kicks on, sometimes I can hear a liquid sloshing sound, almost like when a window-unit air conditioner kicks on. This happens with or without the car A/C being engaged, and seems unrelated to the rattling because the ICE doesn't rattle at these times.
    I guess the car doesn't owe me anything with this mileage, but everything else including the traction battery seems to be working well, and with just having put new tires on it maybe 20,000 miles ago, I'd rather not get rid of it. Do y'all think it's the head gasket? If yes, what would it likely set me back to get this done at the dealership? I'm somewhat mechanically inclined, though I've never done engine work more sophisticated than changing spark plugs. Could I execute this repair myself and not be likely to screw it up?
    I also read about the EGR system potentially being clogged. Would that trigger the "check engine" light? If it has to be cleaned or replaced, would it be best that I get that done while they're doing the head gasket if that's what the car needs?
  2. cnc97
    cnc97 Senior Member
    1,419
    1,528
    38
    Evansville, IN
    You have the dreaded head gasket failure. This is how mine was when I got it. You have options.
    Do nothing, and wait for a sudden, catastrophic failure on the engines terms. You can add stopleak, at your own risk. I got 90 days out of mine when I did the Blue Devil Pour and Go.
    Tear down(or have it done)the engine in the car and replace the head gasket. It can be done with the ICE in the car with some effort.
    Find a replacement engine, as new as possible. If you are up to the mods required, the Gen 4(16+) engine can be used as a replacement.
    Raytheeagle likes this.
  3. RomaniGypsy
    34
    22
    Conneaut, OH
    2014 Prius v wagon
    What's so much better about the Gen 4 engine compared to the Gen 3 engine? And what mods would be required?
    I put more coolant in today and it was doing fine... but it's just a matter of time before the next rattling episode. For what it's worth, I should note that before my last oil change (by now almost 9,000 miles ago), I had checked the oil and noticed what looked like microscopic sediment in the sample at the bottom of the dipstick. They didn't tell me that they noticed anything weird about my oil when I asked the mechanics at the dealership about it.
    Reading through more posts about similar problems, I can say that I noticed something else that others have noticed. Today as I went to put in coolant, as I unscrewed the cap, it released air pressure sort of like a beer can does when you pop the tab. I thought nothing of it, as the engine and cooling system were both around operating temperature by that time, but it happened.
    This "catastrophic engine failure" of which you speak - would it damage the engine to the point that a replaced head gasket wouldn't fix it?
    49,397
    yes, it will blow a hole in the crankcase
    read through some of the head gasket and engine failure threads
    i like your idea, it doesn't owe you anything.
  5. cnc97
    cnc97 Senior Member
    1,419
    1,528
    38
    Evansville, IN
    Click my user name on this post. When you see my profile, click the media tab. I have pictures of catastrophic engine damage. If it happens, it will happen at the worst possible time that you need the car the most.
  6. cnc97
    cnc97 Senior Member
    1,419
    1,528
    38
    Evansville, IN
    There are the obvious ones, the upgraded pistons and rings introduced for the 15 model year. Then the subtle ones, reduced friction bearings in the block and head. I think the number was 12-15% reduction if I recall correctly.
    As far as mods, the radiator hose from the driver side of the head has to be modified. And a couple of small coolant hoses have to be rerouted. Also one of the bosses that would mount the Gen 4 EGR cooler must be ground off, and the Gen 3 cooler cannot be bolted back up, it can only be connected by the manifold pipes. @Ragingfit did a whole video series on it.
    SFO likes this.
  7. RomaniGypsy
    34
    22
    Conneaut, OH
    2014 Prius v wagon
    Man... that engine has been purring like a kitten since the day I got the car. Of all things to be my very first mechanical problem with it... major engine trouble. Any other car it'd be something like an alternator or windshield washer pump.
    Those pictures looked like the engine on my lawn mower looked when, for unknown reasons, something blew through the block as it was running. Now I have to ask... is there a chance that such an occurrence with this engine could send metal flying into the passenger cabin?
    Also - can this happen while the engine still has coolant and has not overheated?
    #7 RomaniGypsy, Jul 14, 2019
  8. RomaniGypsy
    34
    22
    Conneaut, OH
    2014 Prius v wagon
    Update: It was the head gasket. I got it replaced, along with the thermostat and radiator (they must've put in a radiator of questionable quality when repairing the most recent deer collision), and I'm at 226K+ now.
    bisco and Mendel Leisk like this.
  9. Mendel Leisk
    38,653
    Was the egr and intake manifold cleaned? If not, you want to get on that asap. It's debatable, but my 2 cents: it's clogged EGR that's causing head gasket failure: EGR clogs, leading to higher combustion chamber temperatures.
    And consider an oil catch can.
    Boiler plate text on the subject:
    The simplest way to see where you're at, is to check the degree of carbon build up in the EGR pipe, a stainless steel connecting pipe between the EGR valve and intake manifold. Watch @NutzAboutBolts video #16 here:
    Nutz About Bolts Prius Maintenance Videos | PriusChat
    Two or three other videos linked there too, for the full cleaning of the intake manifold, full EGR clean, and Oil Catch Can install.
    Good thread:
    EGR & Intake Manifold Clean Results | PriusChat
    Another:
    Oil Catch Can, Eliminate that knock! | PriusChat
    Some tools worth having:
    E8 Torx socket (mandatory)
    E6 Torx socket (optional, but good to have, to remove the throttle body studs from intake manifold)
    3/8" ratchet wrench, regular and long handle, flex head, you can never have enough (or 1/2 plus reducer)
    1/4" ratchet wrench, or 3/8" to 1/4" reducer
    Ratchet extensions: you can never have enough
    Long needle nose piers, straight and bent tip
    Ratcheting 12mm box wrench (optional, but makes disconnection of the EGR cooler from exhaust easier)
    Torque wrench (3/8" and 1/4" both good to have)
    Floor jack and safety stands (or ramps): basically some method to raise front, if you need to take underpanel off, which you may need to, both for access and to recover dropped items.
    Tim Jones and NutzAboutBolts like this.
  10. satsuke
    satsuke Junior Member
    68
    Was it a clunking // pretty violent shaking for just the first few seconds of startup?
    mine has done that a couple of times when its been sitting a few days, but I haven't noticed any odor.
  11. Fierofly
    Fierofly Member
    35
    Benton, Louisiana
    I believe the clunking and violent shaking could be caused by a piston trying to compress coolant that has seeped into a 13to1 compression chamber. just a matter of time till the rod gives out. It probably only smokes at start up.
  12. Tim Jones
    Tim Jones Senior Member
    1,706
    553
    SE Texas
    2011 Nissan LEAF
    EGR R&R Immediately.......
  13. RomaniGypsy
    34
    22
    Conneaut, OH
    2014 Prius v wagon
    Yes. I caught it once in time to pop the hood and watch. It was rocking back and forth significantly.
  14. bisco
    49,397
    if they didn't clean the egr circuit, at least you know what to expect
    SFO likes this.
