15" Diameter Wheels/Tires verses 17"
Discussion in 'Gen 3 Prius Accessories and Modifications' started by vito.a, Sep 4, 2013.
  1. vito.a
    vito.a Junior Member
    52
    17
    Tucson, AZ
    I'm considering a set of 17" wheels and tires. I'm just not fond of the plastic hubcaps. I researched the OEM 215/45-17" tires and they are slightly smaller (.4" in diameter and 1.2" in circumference) than the OEM 195/65-15 tires. I also found that the 225/45-17 tire is the same size as the OEM 15" tires.
    Has anyone tried the 225/45-17" tires?
    If you switched to the 215/45-17" tires/wheels did you recalibrate the speedometer, or is 1.5% close enough?
    Also, does anyone have data on the differences in MPG between the 15" and 17" wheels?
    Size Dia Cir
    215/45-17 3.8" 12.3" 24.6" 77.3" 819/mi 60MPH 10000mi N/A
    195/65-15 5.0" 12.5" 25.0" 78.5" 807/mi 59MPH 9855mi 1.5%
    225/45-17 4.0" 12.5" 25.0" 78.5" 808/mi 60MPH 10000mi N/A
  2. Mendel Leisk
    40,584
    205/50R17 is also very close to 195/65R15, slightly bigger. It's also more likely to fit on OEM 17" rims, less likely to touch anything, and be better than 215/45R17 for RR, all things being equal. Our Canadian Touring came with the 17", in our case Bridgestone Pilot. They're not rated LRR, but seem pretty good still.
  3. vito.a
    52
    17
    Tucson, AZ
    You're right. The 205/50-17 is only .1" larger in diameter and .3" in circumference.
    Thanks
