15' Plug-in 240v Stopped Working...
Discussion in 'Gen 3 Prius Technical Discussion' started by John Gallenstein, Jul 5, 2017.
  1. John Gallenstein
    John Gallenstein New Member
    Avon Park, Florida
    2015 Prius Plug-in
    I have 15' Prius plug-in. Used 240v charger daily until few weeks ago it stopped working. The standard 110v charger that came still works just fine. Note it's NOT the charger because I had it swapped out, still doesn't work, also the public charger (240v) doesn't work either anymore. Something went wrong in car that won't allow it to charge on 240v anymore... Anyone had this experience? Fixes? Fuse? Help?
    49,397
    welcome!
    that is unusual. toyota did have a bad run of chargers. i would have a dealer take a look, it should be covered by warranty.
    all the best!
  3. Zulat
    Zulat New Member
    Portland Oregon
    Did you get any engine codes with that? Please post what you find out as I have a 2013 Plug-In that isn't charging with 120V.
    Thanks!
    49,397
    welcome!
    did you try another evse?
