15k miles
Discussion in 'Prime Main Forum (2017-2022)' started by eveyo, Oct 2, 2020.
  1. eveyo
    eveyo Junior Member
    85
    2019 Prius Prime
    Hey guys I reached 15k on my 2019 prime. Two questions for you guys
    1) do you guys think its ok to skip the 15k scheduled maintainence? In the midst of covid would like to minimize my trip to the dealer. Seems like its just tire rotation and a bunch of inspections?
    2) when going down hill on a mountain today while in ev mode ( regenerated to 100%) I heard the engine come on and it sounded like when a car is downshifting or in a lower gear when going downhill. When I pushed on the gas it became silent again. Is this normal? is it because of the cvt or because I have fully charged?
    thanks
  2. Trollbait
    12,679
    2) Is normal. If the battery charge goes over the systems high limit, it will spin the engine with M/G1 to get rid of the excess charge, and/or let the engine spin faster for extra engine braking.
    eveyo likes this.
  3. eveyo
    eveyo Junior Member
    85
    2019 Prius Prime
    Is there any harm in this scenario to just leave it in ev or is it better to change it to gas mode?
  4. Salamander_King
    Salamander_King Senior Member
    11,024
    8,970
    New England
    I don't think any harm. The car is designed to do that to protect the battery. Changing to HV mode would still regenerate energy that can not be captured and the end result is more or less the same, engine brake on regen energy wasted. But if you knew the downhill was coming ahead, then try using the traction battery before getting to the top of the hill. That way you will capture the regenerative energy back into the battery. If this was the start of the trip (i.e. You live on top of the hill.) then you could try stopping the charging event earlier say at 80%, to make more room in the traction battery.
    As for the 15k service, if you can rotate tires yourself and check liquid level, I see no reason to make a special effort to visit a dealer. But many dealers are offering non-contact service, so it may not be as risky as you may think. Just ask your dealer how they are handling the COVID-19 situation, and if it sounds too risky, then stay home.
    #4 Salamander_King, Oct 3, 2020
    jerrymildred likes this.
  5. schja01
    schja01 Senior Member
    1,844
    1,226
    Chicagoland
    2024 Prius
    Limited AWD-e
    If only for possible warranty implications I would not skip oil changes. You could even do it yourself just keep the receipts.
    Salamander_King likes this.
  6. Prim.e.xample
    Prim.e.xample Active Member
    164
    107
    Indiana
    2020 Prius Prime
    I would check with your Toyota dealership about COVID precautions. Mind did a good job funneling people in/out and socially distancing them. I don’t know what could be done about the tech in the car though unless they wipe it down for you?
    pghyndman and jerrymildred like this.
  7. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    100% Normal...that is engine braking and it comes on because you were fully charged and there is no more room in the battery for additional regen charging. You don't need to switch drive modes. The only thing to consider is switching to B "gear" if you have to ride the brakes to maintain a safe speed, since all braking at this point is from the friction brakes, and you don't want to overheat them.
  8. eveyo
    eveyo Junior Member
    85
    2019 Prius Prime
    thanks guys this is very helpful. Next time I go down this mountain I will have far less charge but its good to know this is all normal. I started at around 70% and regernaterd to 100%. Based on the mountain I likely could have regenerated from 20 or 30%.
    As for the 15k service I will do the service myself since it only seems to involve mainly tire rotation.
  9. RustyRaven
    RustyRaven New Member
    Ventura County
    2020 Prius Prime
    I took my Prius to the dealer for its 5K warranty service. I felt they did a very good job of observing social distancing and the wearing of the masks. There were very few people in the dealership too.
