16” OEM to 15” Gen 3 OEM
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Has Raf, Apr 18, 2025.
  1. Has Raf
    Has Raf Member
    180
    42
    Stoke-on-Trent, England
    Would it be worth going from 16” OEM alloys to 15” Gen 3 OEM alloys, on my Gen 2? The goal is comfort, quieter ride and a bigger sidewall. Tyre prices are about the same for both tyres I’m looking at (205/60R16 and 205/65R15).
    Also, is it worth removing a 1.6” and reverting back to stock ride height, to achieve comfort and a quieter ride?
  2. MAX2
    MAX2 Senior Member
    1,436
    483
    101
    Third planet from the Sun
    Are you sure you got the generations right?
    On Gen2 the tire size is 195/55R16 Europe, 185/65R15 USA
  3. Has Raf
    Has Raf Member
    180
    42
    I’ve got a lift kit on so, when I get new tyres, I’ll be getting larger ones compared to stock. I’m in the UK so my current tyres are 195/55R16.
  4. MAX2
    MAX2 Senior Member
    1,436
    483
    101
    Everything is correct now. 195/55R16 Europe
    Regardless of whether the car is raised or lowered, the distance inside the wheel arch remains the same, and when you insert a wheel (205/60R16) whose diameter is 32 mm larger, the wheel will start to touch the wheel arch.
    Use a tire calculator.
  5. Has Raf
    Has Raf Member
    180
    42
    I have. See below. But my question is whether it’s worth buying smaller 15” alloys to improve ride quality and comfort.
  6. MAX2
    MAX2 Senior Member
    1,436
    483
    101
    You can see that they are different.
    If you decide to install 15 wheels, then the tires should be 185/65/R15.
    The ride will be softer.
  7. Has Raf
    Has Raf Member
    180
    42
    185/65R15 will be softer than 205/65R15? My question is, should I reduce from 16” alloys to 15”, or is it not worth buying new alloys? They’re about £200-300 here used for a full set of 4.
  8. MAX2
    MAX2 Senior Member
    1,436
    483
    101
    205/65R15 is a significantly larger tire than 185/65/R15 or 195/55/16.
    This size can get stuck in the Gen2 wheel arch.
    185/65/R15 will be softer than 195/55/16.
  9. Has Raf
    Has Raf Member
    180
    42
    You’re not answering my initial question.
  10. dolj
    dolj Senior Member
    8,209
    4,180
    Wellington, New Zealand
    The correct size in the UK for 15" wheels would be 195/60 R15, which is also what I run here. Use the calculator to find the correct wall height ratio for the 205 width.
    I can't really offer any perspective on 185 vs 195 vs 205 as I have only ever run the 195/60s.
    I use the stock 15" wheels for the Gen 2.
    I would think the ride comfort difference of 16" vs 15" would be pretty minimal, but I have no real data to support that.
    The greatest difference for ride comfort would be the actual tyre manufacturer, from my experience. I have had Goodyear, Firestone, Hankook, Bridgestone, and now currently running Michelin (Energy XM2+), and the only tyre that I even noticed a softer ride on was the current Michelin tyres.
    Tyre pressure makes a difference too; the higher the pressure, the harder the ride. I run the Michelins at 35 PSI front and 33 PSI on the rear as I have with all my tyres over the years.
    Has Raf likes this.
