16' BRZ seats into 12' Prius C
Discussion in 'Prius c Accessories and Modifications' started by CJSK, Sep 16, 2018.
  1. CJSK
    CJSK Junior Member
    Here is what im half way done. Ill make a full post later on with issues i had and what i had to do.
    It feels good. Like really good! And after 144908 on the odo the stock seats were in a bad way. 20180916_021457.jpeg 20180916_090821.jpeg
    51,985
    wow!(y) what is a brz?
    Danny13pruisc3 likes this.
  3. MichaelKnight
    MichaelKnight Junior Member
    39
    22
    Westcoast
    Thumbs up like Bisco mentioned. Does that mean you will be do the passengers seat too? And how about the connector underneath and if the airbag functionality? regardless will wait on your full write up......
    Just encase.....
    2018 Subaru BRZ - Sports Car | Subaru Example of 2019 Subaru Brz....
    2019 Toyota 86 Sports Car | Track proven. Street ready. Toyota example same chassis
  4. CJSK
    CJSK Junior Member
    Yes ill be doing the passenger seat as well, actually 3 connectors underneath it.
    Wait for it all on the full writeup, should have that up end of the week
    ztanos likes this.
  5. Anthro
    Anthro old member
    58
    Boulder, CO
    2021 Prius
    CJSK, I'd love a real bucket seat like this and look forward to your write-up. Was there a particular reason for a BRZ as the source, or might other sources be as good?
    LnG likes this.
  6. Leadfoot J. McCoalroller
    8,092
    7,577
    Pennsylvania
    2018 Prius c
    The BRZ/FRS already has some (very little, but some) parts commonality with the Yaris/Aqua/Prius c.
    Beyond that, it's a very similar-sized cockpit. Much more likely to fit than the couches from an Escalade or something.
    Nice work, I bet it is going to have great support.
  7. Jdracer
    Jdracer Junior Member
    Bay Area
    2020 Prius Prime
    Some BRZ seats showed up locally and thinking of purchasing. Did you ever draft up a write up yet?
    emune likes this.
  8. Royston.K
    Royston.K Member
    75
    60
    Singapore
    Thanks to TS and I happened to have a pair of seats from BRZ/86/FRS which was fitted in my previous ride Volvo C30 T5. I have all the original railings intact so I'll be doing the swap as soon as I find time.
  9. emune
    emune Junior Member
    26
    2016 Prius c
    What seat rails / brackets did you use? I want to run a bucket seat in mine but haven’t found what rails would work
  10. Royston.K
    Royston.K Member
    75
    60
    Singapore
    A little work to get these in.
    #1. Remove donor seats rail
    #2. Remove original seats rail
    #3. Bore donor seats mounting point for rail to be wider to fit original seat rail as they are wider than donor seats (Important step. Without doing this factory rail will be too tight and you will have issue with seat sliding mechanism)
    #4. Mount original seats rail onto donor seat
    #5. Plug & play with factory rail, airbag harness and seat belt buckle should also be plug & play.
    Please check the seat bolt as they are uncommon size.
  11. Monkeyofmyth
    Monkeyofmyth New Member
    Vancouver, WA
    2015 Prius c
    Did you unplug the battery before doing the swap?
  12. Jumpedinthepriasus
    Jumpedinthepriasus Junior Member
    46
    Ct
    Always when dealing w the airbags
