'16 Lowering Springs?
Discussion in 'Gen 4 Prius Accessories and Modifications' started by DieselHybrid, Feb 26, 2016.
  1. DieselHybrid
    DieselHybrid Junior Member
    36
    Mid-Atlantic
    The handling of the '16 Prius is amazing!
    For reference, I owned an '11 Prius which I modded with TRD Prius Plus lowering springs & a rear sway bar.
    The stock Prius 2 Eco handles better than my '11 in all respects... but it is not quite perfect- yet.
    Personally, I would like to find lowering springs. Nothing crazy, just a mild 1-1.2" lowering would be ideal in my opinion.
    Anybody making them for the US market yet?
    Thanks in advance!
    P.S.- anybody want a lightly used Gen 3-specific rear TRD sway bar? :)
  2. Lucifer
    Lucifer Senior Member
    1,014
    485
    Nh
    The gen4 is .9" lower then the gen3, I was assuming toyota put the trd springs on the gen4 as they lower the gen 3 about .9", you might look into the koni stock prius shocks.
  3. cjecpa
    cjecpa Member
    160
    58
    rsrusaThe all new 2016 Prius Down Sus springs are now complete.
    Front
    Rate: 2.90kg/mm
    Drop: -30~-35mm
    Rear
    Rate: 3.88kg/mm
    Drop: -20~-25mm
  4. krmcg
    2,592
    2,390
    Whittier, CA
    Tanabe has springs.
