16" rims on snow tries
Discussion in 'Gen 4 Prius Main Forum' started by 8Nguy500, Jun 9, 2020.
  1. 8Nguy500
    8Nguy500 Junior Member
    24
    Wisconsin
    2019 Prius
    Hello All,
    I just brought my third Prius yesterday. A 2019 Prius Four in Charcoal grey. Big tablet size screen in the middle of the dash, heated seats and steering wheel. Just a great car.
    My question is it has 17" rims. On my previous cars had had 16" rims with snow tires. Can I run them on this car? Do I need to make any adjustments on the car?
    Thanks for your replies.
    I have a correction my snow tires are on 15" rims not 16". They are 195/65R15 . I have them on 2012 Prius rims. Sorry for my mistake. Thanks for the replies.
    #1 8Nguy500, Jun 9, 2020
  2. Mendel Leisk
    38,651
    I'd suggest 195/65R15 for snow tires. Personally, I shy away from aftermarket, one-size-fits-all rims. For a black steel rim, there's a Toyota Corolla rim that's 100% compatible. This is what I'm using, fwiw:
    Corolla 15" black steel rims p/n: 42611-02471
    With lug nuts p/n: 90942-01007 (utilitarian, open-ended, galvanized)
    One thing, I found the lack of centre caps meant the hubs were turning into rust lumps real fast. And they looked bad. After a couple of winters thus, I cleaned them up best I could, applied some coating. then used 2" ABS end caps as a cover. They're slightly loose, but I found pushing a rubber band onto the lip on the rim first, made the cap a snug/secure fit.
    If you want something classier, 15" Prius alloy rims with centre caps?
  3. krmcg
    2,592
    2,390
    Whittier, CA
    Yes, you can run your 16" wheels on your new Prius. No adjustment required.
  4. JStrenk
    JStrenk Active Member
    203
    101
    Ravenna
    I run my 15" 2010 Prius rims on my 2016 prius for snow tires.
    They have 195/65R15 Blizzacs on them.
    Yes I see your correction on rim size.
  5. Mendel Leisk
    38,651
    Yeah our 2010 has the stock 17" rims, but I use 15" for snow tires.
