17 days sitting - dead battery?
Discussion in 'Gen 3 Prius Main Forum' started by Acre, Jan 11, 2010.
  1. Acre
    Acre New Member
    104
    Woodside, CA
    I'm out of the country for 17 days. What's the latest on the dead battery problem discussed some time back? I have a Prius II so there are perhaps fewer things drawing juice than with higher end models. This is Northern California so it might freeze at night but it won't get wicked cold.
    Thoughts?
    Anything I can do to avoid a problem?
  2. 32kcolors
    32kcolors Senior Member
    5,683
    953
    124
    Redondo Beach, CA
    Who wants to start a betting pool on this?
  3. don_chuwish
    don_chuwish Well Seasoned Member
    816
    182
    Southern Oregon
    Where will it be parked? Not at the airport I hope. If not, BatteryMinder maybe? Or disconnect the ground. What's the manual say?
    For my Gen II I would just turn off the smart key system and hope for the best.
    - D
  4. leeb18c
    leeb18c Active Member
    272
    202
    SF Bay Area
    Maybe carry one of those battery boosters. Even the smallest one would do with Prius since it just need to boot the computer & some relays.
  5. PaJa
    PaJa Senior member
    678
    113
    92
    Czech republic
    Don't do anything special. Just check if all visible power consumers are switched off, like map lights, cargo light and so on. SKS will go to low power mode automaticaly, if you didn't ask the dealer for the special setting via Techstream.
    This is Gen III, not Gen II.
  6. Darwood
    Darwood Senior Member
    5,259
    268
    Ask a neighbor to come start it once while you are away.
  7. going red baby!
    going red baby! still a n00b
    610
    96
    Los Angeles
    Ask your neighbor to turn it off again sometime after he starts it.
  8. creativeguy
    creativeguy Member
    301
    17
    CA
    I just left mine in my garage for 11 days and it had no problem. Traction battery didn't even lose a bar. I think this fear is overblown.
  9. antoine
    antoine New Member
    29
    maine
    My dealer tells me to pull the "short fuse", which is a white fuse in
    the center of the fuse box near the rear of the fuse box. He has a
    "notice" that says that this fuse is pulled for shipping and that the
    dealer must insert it during vehicle preparation. It will kill power
    to the SKS system (big user of power when car not running) and
    a few items on the dash like the trip odometer settings. I only
    tried this for a minute and in that time, I did not lose my radio
    station settings.
    My Prius is in a neighbor's garage now for 2 months. We'll see
    how this works. A battery jump box is a sure way to insure you
    can start the car, but decent ones cost around $90-$145 and they
    need to be maintained (charged).
  10. c64rbr
    c64rbr Junior Member
    16
    Houston, TX, USA
  11. dorboy
    dorboy Junior Member
    Dorset UK
    I was concerned about leaving my 2007 Prius Tspirit in the UK for 3wks over Christmas. I took the precaution of making a good run in daylight so that the big battery was well charged. Then I left it double locked, with the footbrake off to avoid seizing.
    Afte 3wks and a day, it started no problem at all. Everything seemed normal, so now I will not worry so much.
