17" OEM Toyota Wheels - Anyone?
Discussion in 'Prime Accessories and Modifications' started by 303inthe510, Apr 17, 2018.
  1. 303inthe510
    303inthe510 Member
    65
    70
    Oakland, CA
    [I've searched the forums and found very little on OEM wheel swap - not after market wheels]
    Has anyone installed Toyota OEM wheels? I'd love to see your pics! :)
    I'm not a huge fan of the Prime's standard 15"ers. Maybe I need longer than 3 days to adjust to them, but my former 2017 Prius Touring had 17" wheels as did my 2012 Prius Five, and I sorta miss that look.
    These pictured here are two options from the current gen Corolla 'S' model. They seem to be the same bolt pattern, I'm curious how they'd look. I saw one forum member's Prime with Toyota 86 wheels that looked great, but I don't want to deal with spacers, etc.
  2. Rob43
    Rob43 Senior Member
    1,373
    1,047
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    Your only real problem with your two pictured choices are weight, Toyota OEM 17's are heavy.
    Unsprung weight is your big enemy on a PP. Try to figure out the weight of each of your proposed wheels before you buy them & list them here.
    Rob43
    303inthe510 likes this.
  3. JMalmsteen
    JMalmsteen I love my Prius!
    275
    262
    Long Island, NY/Lancaster, PA
    I got aftermarket wheels for mine.
  4. Salamander_King
    Salamander_King Senior Member
    10,970
    8,853
    New England
    I have seen some people upsizing tires on Prime, and I know some of Prius models do come with OEM 17" wheels standard. But, are there any advantage of bigger wheels on Prime other than looks?
  5. 303inthe510
    303inthe510 Member
    65
    70
    Oakland, CA
    I'd be doing it more for looks (personal preference), but improved handling should also be achieved. To me, it's more pleasing to see a larger wheel than larger tire sidewall. It's likely a combo of suspension tuning + 17" wheels, but my 2017 Prius Four Touring felt much more connected to the road around curves.
    Salamander_King likes this.
  6. Trollbait
    11,512
    But you will pay for those looks and handling through lower efficiency and thus shorter EV range. Or through a high price tag for a wheel and tire combo that doesn't increase in weight.
  7. 303inthe510
    303inthe510 Member
    65
    70
    Oakland, CA
    True.
    Perhaps I'd be better served finding Prius Touring wheels. Those yielded great [EPA] mileage in my 2017 (lifetime of 5,300 miles was 52.4 MPG, and I live in a hilly area).
  8. Rob43
    Rob43 Senior Member
    1,373
    1,047
    2013 Prius v wagon
    Read my Sticky thread on Prius Prime wheels if you haven't already & then reconsider your stance on buying OEM 17's.
    Aftermarket Wheel Fitment Guidelines | PriusChat
    I'm totally with you on wanting/needing 17" wheels, but I'd never consider OEM 17's because of the added weight, I
    guesstimate the weight of each of your Corolla wheels at roughly ~25 lbs. Based on averages you'd end up at ~44 to ~46 lbs
    per wheel/tire which is roughly ~29% to ~35% above stock OE.
    Rob43
  9. 303inthe510
    303inthe510 Member
    65
    70
    Oakland, CA
    Good read (sticky) -- thank you for the link. Hmmm. I may be leaving those 15" wheels in tact, after all! :unsure:
  10. Rob43
    Rob43 Senior Member
    1,373
    1,047
    2013 Prius v wagon
    I'm Totally Encouraging You to go with your 17" wheels & tires, I'd just recommend that you'd look at all your different options
    so that you keep your unsprung weight as low as possible based on your budget.
    As an example: I just bought my 17" tires which weigh in at 19.2 lbs each, I'm still making my final decision on my 17x7"
    wheels. If I buy the wheels that are currently at the top of my list, they weigh in at 17.0 lbs; so theoretically my wheel/tire
    package would weigh in at 36.2 lbs.
    Rob43
  11. E-GINO
    E-GINO Active Member
    194
    206
    Rome, Italy
    I had the 17" rims on my Gen 3, boy what a difference in comfort with the 15" I've got with the Prime, the handling is also much improved, probably it would improve more with the 17" rims but for sure at the expenses of both comfort and fuel economy.... the design of the 15" OEM rims is not bad too, in fact I've bought another set of OEM rims for the winter tyres. Also even if OEM rims are more expensive of non-OEM rims you don't have to deal with centering rings, which may cause offsets and induce vibrations.
  12. 303inthe510
    303inthe510 Member
    65
    70
    Oakland, CA
    Thanks for sharing that pic. If our US Primes came with those wheels I'd be completely fine with them. It's the plastic wheel cover thing that I just don't like. And the wheel beneath it isn't my favorite, either. I was in Rome in October and didn't see a single G4 Prius or Prime, but many G3s.
  13. Mendel Leisk
    38,653
    The rims on 2012~2015 PIP were good, the only decent 15" rim on a Prius.
    Glenn G likes this.
  14. benagi
    benagi Active Member
    525
    280
    Utah
    Does anyone know if the 17” wheels off of a 2012 Prius v advanced wil fit on the Prime? And if so, do I have to reprogram the tpms?
  15. Rob43
    Rob43 Senior Member
    1,373
    1,047
    2013 Prius v wagon
    They won't fit, unfortunately they're 5x114 bolt pattern...
    Rob43
  16. benagi
    525
    280
    Utah
    Thx Rob for the reply and info.
  17. E-GINO
    194
    206
    Rome, Italy
    Well I don't see why you can't get the OEM (EU) rims through your Toyota dealer, my second rims set came directly from Japan after two weeks from the order.
    In fact here Gen 4 here are very rare. Unlike Gen 2 and Gen 3, Gen 4 did not encounter the favour of taxi drivers and citizens sensible to environment issues for several reasons, the main one being the fact that other Toyota hybrids are a lot cheaper (Auris/Corolla) or more functional (Auris SW, Prius V etc). The Prius Prime (Prius PHV here) has no chances at all here, too pricey (10000 Euro more than Gen 4) too long for the typical urban parking spot, only 4 seats with reduced luggage room, and (coup de grace) there are no Government incentives.
    That said, I am happy, enjoying the EV drive in the city and feeling like I was driving a custom car..
  18. Rob43
    Rob43 Senior Member
    1,373
    1,047
    2013 Prius v wagon
    Got these today.
    Rob43
    benagi likes this.
  19. Glenn G
    Glenn G Member
    117
    63
    North Andover
    2018 Prius Prime
    I received a tire and rim from the dealer as a part of the sales agreement since my 2018 Prime didn't have a spare.
    So...I still have my Michelin X Ice tires and they have enough tread on them to go through another winter.
    In the past I had them swapped on to the rims of my Prius (2011) & then 2015. Now that I have another available rim
    I decided to put the snows on their own rims.
    I found some after market rims at Tire Rack that were similar to the factory rims, but I was concerned that they wouldn't be an exact match. I found some rims on Ebay - they were listed as 2009-2015 Prius rims, but they looked like my rims.
    I sent the seller a photo of my rim with the numbers and he indicated that it was the same as the rims he was selling.
    He accepted returns, so I bought 3 rims from him. I had them installed and all is well. The tire store told my
    wife that the wheel covers don't fit these wheels, but the wheels look good, and it's only 2 1/2 months until they come off.
    In short I obtained some factory wheels that fit for ~$100.00 each shipped. Here's one of them (3 separate purchases):
    https://www.ebay.com/itm/15-INCH-TOYOTA-PRIUS-2010-2014-2015-OEM-Factory-Original-Alloy-Wheel-Rim-69567A/192680208626?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
  20. Woodman411
    Woodman411 New Member
    23
    New York, NY
    Rob, do you have rim strength measurements besides going strictly by weight? I ask because although even the best can crack if there is enough impact, I'm guessing the heavier OEM's can take more stress than lighter made-in-China rims. I'm sure there is a balance between weight and strength and cost (pick 2), just no easy way for a consumer to see a rim's strength (if potholes aren't an issue in your particular area, obviously this concern will have less relevance. Otherwise, plenty of examples of bent/cracked/broken rims).
    #20 Woodman411, Jan 16, 2019
    douglasjre likes this.
