17 toyota prius two eco
Discussion in 'Gen 4 Prius Technical Discussion' started by Godzilla007, Nov 6, 2020.
  1. Godzilla007
    Godzilla007 Junior Member
    Phoenix
    Hello all!
    So I sold my 2010 Prius and bought a nice 2017 two Eco with only 43,000 miles on it.
    I noticed the the center vent driver side doesn't blow any air, all other vents blow air.
    Any idea or maybe some sort of setting?
    Possible air vent flap stuck or broken?
    Thank you,
  2. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Yeah, check the inside for blockage first. Another cause is a faulty blend door but that typically affects more than one vent at a time. There have been a couple of reports here of those failing in the gen4 platfrom (includes prime). My 7 year old C-Max has only had one issue and that was very early on with a blend door controller that was fixed under warranty.
    GOOD LUCK!
    52,677
    congrats!
    check the o/m, it might be adjustable/programmable
    all the best!(y)
