Prius generation matters for "short pins TS & CG" kinds of procedures!
Discussion in 'Generation 1 Prius Discussion' started by ChapmanF, Feb 19, 2017.
  1. ChapmanF
    18,548
    There are various procedures in the manual that can be done one way using a computer and Techstream, and another way by shorting some pins at the diagnostic connector.
    Toyota's instructions refer to the pins by name, like CG, TC, TS, or AB.
    When I had my Gen 1, I learned which pin numbers those were by looking in the manual.
    Then I assumed they'd be the same in my Gen 3. Hello!
    CG is still pin 4. TC is still pin 13. I don't think there's an AB pin any more (in Gen 1, you could command the airbag ECU with it).
    The treacherous one is TS. In a Gen 1, it's pin 14, but in a Gen 2 or 3, it's pin 12! (In a Gen 4, I don't think there is a TS.)
    They apparently moved it when they started using CAN in Gen 2, because the old pin for TS, 14, is one of the defined CAN pins.
    So if you're in a Gen 3 and you mistakenly try a "TS-to-CG" procedure using the pin numbers you remember from Gen 1, you end up grounding a side of the CAN bus, which isn't a disaster, but produces a chorus of DTCs from a heap of ECUs that temporarily couldn't talk to each other, that you then have to go and clear.
    And if you're working on a Gen 1 using pin numbers you learned from Gen 2 or Gen 3, that won't work either. :)
    -Chap
  2. Andrew J
    Andrew J New Member
    For my 2011 Prius (piece of crap), I have this. Does anyone see anything out of whack? Not sure that I have TS/TC right, may be the reverse.
    p01 p02 p03 p04 p05 p06 p07 p08
    nu nu nu CG SG CH KB nu
    IG nu nu TS? TC? CL nu Pwr
    p09 p10 p11 p12 p13 p14 p15 p16
    CG chassis grd
    SG signal grd
    CH CAN Hi
    KB Kbus
    IG Ignition (pulsed upon ignition)
    TS Toyota Status
    TC Toyota Control
    CL CAN Lo
    Pwr 12v power
    nu not used
  3. Brian in Tucson
    Brian in Tucson Active Member
    981
    453
    Tucson AZ
    2003 Prius
    You do realize that this part of Priuschat is for gen 1 Pri's? You might try posting your questions in the appropriate section of the forum.
  4. ChapmanF
    18,548
    It doesn't sound like he likes his Gen 3. Maybe he aspires to have a Gen 1.
    Brian in Tucson and WHCSC like this.
  5. Brian in Tucson
    981
    453
    Tucson AZ
    2003 Prius
    Kinda sad, ain't it?
