17mpg on my prius
Discussion in 'Gen 2 Prius Fuel Economy' started by Uwana, Mar 23, 2025.
  1. Uwana
    Uwana New Member
    Nigeria
    Hello everyone, I recently purchased a Prius, everything seems ed to be working fine ithe the vehicle. After a month of driving, I noticed that I'm averaging 15-19mpg on the car. I know this is not normal. I've spoken with my mechanic, he says that there's nothing wrong with that number as most Prius's he fixes always hit that mpg, but my guts is telling me that something's off.
    I noticed that when accelerating the car sounds like it struggling to cope. I've done alot of research and can't seem to diagnose the issue. I'm constantly on the look out for error codes but the vehicle hasn't had any pop up.please help!!!!
  2. MAX2
    MAX2 Senior Member
    1,436
    488
    101
    Third planet from the Sun
    There are many factors that affect consumption.
    Fuel quality, duration and frequency of trips, driving style, serviceability of all systems in the car.
    For more precise control, you should purchase some device that will read the parameters of your car's operation for further analysis.
    You can install the program on your phone for free. Hybrid Assistant can be a good fit for this.
    Hybrid Assistant
  3. dolj
    dolj Senior Member
    8,559
    4,349
    Wellington, New Zealand
    You only drove 10 miles. You are not going to get economy starting from cold and only driving 10 miles. Make longer trips, and don't reset the average consumption after every trip, only after every refill (filling the tank from empty to full) is enough.
    Pd30242 and Brian1954 like this.
  4. Pd30242
    Pd30242 Junior Member
    26
    Chicago
    Could be anything. It would help if you gave us what diagnostic steps you've already taken. I know some usual suspects are stuck brakes, dirty MAF, clogged injectors, dragging undertray, bad battery, etc.
  5. bisco
    52,391
    do a couple tanks and calculate at the pump
  6. pasadena_commut
    pasadena_commut Senior Member
    2,852
    850
    Southern California
    In 10 miles and 30 minutes our Prius has usually warmed up fully and is averaging over 40 mpg around town and close to 50 mpg on the highway. However, it will be substantially lower if the trip consists mostly of very short jaunts and then the car idles for 5-10 minutes at a time with me in it while the wife runs into one store or another. Going up hills, or even long shallow grades, also causes a huge hit. (Although typically made up when the vehicle descends again.) Running the A/C will also lower mpg a lot at low speeds, less so at sustained higher speeds. Since the screen shot shows 88F it seems likely that the A/C is on.
    All that said, do check the engine's air filter, and after driving for a sustained 15 minutes at 30 mph or more, stop and feel all the wheels to see if any are substantially hotter than the others (dragging brake or really bad bearing).
    This model car is not a rocket at the best of times. However, when the high voltage battery is on the way out it can become distinctly sluggish, which may be what you are describing as "struggling to cope". How old is the high voltage battery? The pack can degrade pretty substantially without throwing any codes. If you see the state of charge indicator collapsing frequently (from many bars to few bars, then terrible acceleration while it charges back up) that is a sign that it needs a new pack, or at least a pack reconditioning. If you can get a paid copy of Dr. Prius and a compatible OBD2 adapter there is a test which gives an estimate of the state of the pack.
  7. asjoseph
    asjoseph Samuel, '04 Ruthiemobile
    97
    34
    117
    lancaster, california
    ... here, in California, it's the gasoline. We get awful fuel consumption. Worst MPG in the nation, we pay more than anyone, for it.
    Here in California, our gasoline is specifically formulated to get the car through smog check. Try to spike the tank, we risk the car failing, at smog check. Fresh catalytic converter, impeccably maintained gen II, 204k on the odometer, 14k on a professionally rebuilt engine, driving like a grandma, I'm having a time of it seeing 40 mpg, across level ground.
    Outside California, I'm into the mid-to-high 40s. Crossing the state line, gassing up outside California, I see a 7 to 12 mpg improvement, substantial increase in cruising range. Once back in California, I'm back down, in the 32 to 37 MPG range.
    Always shortchanged, here in California, we're getting boned! Not with anything here in California do we ever get what we're paying for. My supercharged AW11, once a 25 mpg vehicle, I'm getting just 8 to 12 mpg on summer blend -
  8. pasadena_commut
    2,852
    850
    Southern California
    I'm burning the same gas and our 2007 is usually around 43 mpg in mostly city driving within a broad flattish valley. It gets around 50 mpg on the highway, again, with the same gas. Elevation changes of a couple of hundred feet are common on a trip of more than 5 miles. The only way our car would have mpg as low as asjoseph cites would be if we only made very short trips, or it developed a mechanical issue. That the mpg goes up when going out of state, which would likely result in longer drives, suggests that short trips might be the issue.
    Californians do get screwed on the price of the gas though, with the extra being state taxes plus some crass supply manipulation by the oil companies. One refinery will go off line for planned maintenance and another will always mysteriously have some sort of unplanned outage. Prices jump very rapidly and then return to the lower values only very slowly. This is usually when they change the gasoline mix seasonally.
    Most of the population lives in areas surrounded by high hills or even mountains. Without heroic efforts at pollution control we would be back in the bad old days when I couldn't see the mile high mountains just a couple of miles away, and a short run made a person feel like they had COPD. I recall flying into Burbank on heavy smog days and it was almost like landing twice, first on transitioning from clear air to filthy air, at which point visibility would suddenly drop from 20 miles to less than 1 mile, and then secondly when actually touching down.
  9. asjoseph
    97
    34
    117
    ... fuel contamination issue can't be confined, to just Ohio:
    Push on again to test Ohio gasoline for quality | Just The News
    If our policy community wanted us getting superb mpg, we'd be getting superb mpg. We're not. Because the policy community has a pecuniary incentive, we don't? We're getting boned.
    I'm seeing significantly diminished fuel efficiency, across every vehicle I own. Unless I venture out-of-state, I never see 40 mpg on my '04 hybrid, anymore. Everything else I have, well under 20 mpg.
    Once a solid 25 mpg vehicle, my 2300 pound supercharged AW11, I'm down into single digits -
    Samuel, '04 Ruthiemobile -
    #9 asjoseph, May 9, 2025
  10. MAX2
    MAX2 Senior Member
    1,436
    488
    101
    The correct fuel-air mixture requires two components: gasoline and air.
    You do not take into account that the air in California is better than in other states.
    Therefore, to spoil it, you need more fuel consumption and therefore a decrease in MPG.
  11. KitsuneVoss
    KitsuneVoss Member
    371
    55
    Virginia
    I replaced my roommate's fuel injectors and the MPG went up so much that they are better than when she first got it and no codes. I was driving it last weekend and got up to 53 mpg.
    Also, I had a tire that had a broken tread and/or bubble in it. Replacing that tire increased my MPG. I replaced my own fuel injectors, my MAF sensor (from a wrecked vehicle), and had the catalytic converter replaced, and that appears to be improving my MPG. Could try the as well.
  12. pasadena_commut
    2,852
    850
    Southern California
    I think I'm done feeding the troll.
    I had a Mazda 323 years ago which was getting 23 mpg. It ran fine. My mechanic thought it could be better though, so he suggested cleaning the fuel injectors, and I agreed. The fuel economy went up to 27 mpg, a solid 17% improvement. So yes, dirty fuel injectors can really pull down a car's fuel economy, even when the car is not obviously running poorly. (Not taking into account all the information that is now available with modern OBD2 tools and sensors.)
    That said, after reviewing asjoseph's recent posts it does not appear that repairing the vehicle is his primary reason for posting here.
    Brian1954 likes this.
