19 or 20 inch wheels for gen 3?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by santaclaraguy, Jul 15, 2009.
  1. santaclaraguy
    santaclaraguy New Member
    Oregon
    Ive searched only found people talking about 17" and smaller wheels for the prius...
    If I was to put some large diameter light weight (close to OEM weight as I can get) wheels and tires on the Gen 3, say 19" or 20" diameter, would it effect the car in a negative way? I'm not talking about gas mileage... I'm talking about the computer? batteries and how they recharge, etc...
    IF you have pics, please post or link them for me to see.
    Thank you
    SCG
  2. accordingly
    accordingly Member
    268
    63
    Madison, WI
    As long as you get the same outside diameter as the stock tires, you shouldn't have a problem as far as the speedometer goes. Wheels and tires have no bearing on any 'computer' or hybrid system components or anything else. You'll only notice a handling difference as a more 'sporty' ride which is either negative or positive depending on your preference.
    At the 19" and 20" sizes, the wheels and tires start getting wide though, so there may be some rubbing issues when turning hard. Maybe you'd have to roll the fender. I suspect there will be a limited selection in wheels and tires that will fit, but like anything I'm sure it can be done if you're willing to pay.
  3. nineinchnail1024
    nineinchnail1024 New Member
    280
    40
    New Orleans
    Yes. It would look terrible. ;)
  4. santaclaraguy
    Oregon
    Thank you for the replies. Good to hear it will not effect the hybrid components. I know it is really difficult to get the exact outside diameters, so the spedo will probably be off. But my gps will keep me in line with that.
    Its funny how some people don't like small wheels and some dont like large. Everyone has there own opinion. ^_^
    If anyone has any other feedback, I'm willing to read it.
    SCG.
  5. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    Here's my $0.02. With 19" or 20" wheels, the sidewalls are going to be so extremely low profile, it's going to be like driving on rubber bands. Very harsh ride, and prone to damage from road imperfections.
    And even on a sports car, going to 19" or 20" typically decreases handling performance compared to 18" wheels.
    As for looks (not that you asked)...my mother taught me if you don't have anything nice to say, don't say anything. :D
  6. hill
    8,188
    oh yea . . . it's a good look . . .
    all you'll need is a couple circus clowns along side of you, with big shoes and honking horns
    :p
  7. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    experiance people... the OP is looking for experiance.
    there was an L.A. dealer that used to equip Gen II models with 18 inch rims with no problems... and my Gen II has 17's on it.. (same as the package V gen III) sooo... i assume 18's or 19's would fit.
  8. Flying White Dutchman
    4,374
    313
    there are also nice 15 inch.... better mpg
    mm maybe i can get some 12 inch? low rider.... right?
  9. V8Cobrakid
    3,790
    152
  10. V8Cobrakid
    3,790
    152
    the thing that's nice about a larger wheel.. my 17's for example... less wheel flex equals better acceleration out of parking lots and through corners... the tire's on the Gen II's likes to trip traction control.. but with my larger wheels, it squeels and actually accelerates. (no tripping traction control) im' not sure how entrusive the control is on the Gen III's...
    you Will feel the road a lot more. maybe not the little bumps.. but you'll feel the contour of the road more... it feels like the front end is twisting instead of absorbing.
  11. Flying White Dutchman
    4,374
    313
  12. yardman 49
    yardman 49 Active Member
    606
    77
    Northern Kentucky
    Another issue is that your MPG (as calculated by the car) will be wrong if the overall tire dimension changes (gets larger).
    You probably should put some spinner hubs on there too....:smokin:
  13. santaclaraguy
    Oregon
    Looks like ive got a lot of people thinking. ^_^
    I'm not going for the bling look or anything that would add shame to the prius culture... just thought it might look a little better to have a slightly larger wheel since gen 3 looks really sporty (to me). I saw one at the dealer with the 17's and it looked really nice so perhaps 17's or 18's would do the trick (apperance wise).
    Other than all the opinions, it sounds like it is possible and it won't effect the hybrid parts, but will mess up the spedo and the mpg calculator (and of course the gas mileage).
    Being new here, i need to look through the threads of pics of gen3's with custom wheels. I saw one yesterday as I was browsing.
    Thanks,
    SCG
  14. accordingly
    accordingly Member
    268
    63
    Madison, WI
    As long as you keep the same outer diameter you will not affect the speedometer or the mpg calculator much at all.
    MPGs themselves are going to come down to the unsprung weight and the amount of rubber on the ground.
    18s are definitely an option. To match the outer diameter, 225/40-18 is a real common size but may be too wide. 215/40-18 are available as well in a more limited selection.
    The big problem I would think is once you start getting into 19 and 20 inch sizes, the sidewall profile is going to be tiny. You're going to start to get into the 'hard as a rock' handling zone. If the looks are more important than the plush ride, then go for it!
  15. santaclaraguy
    Oregon
    I know this is a Gen2 but something clean like this is what I'm going for...
    Anybody have custom rims on a GEN3? post pics to help me out please.:rockon:
    Thanks,
    SCG.
  16. dogllama
    dogllama New Member
    118
    Los Angeles
    I like the look of the bigger wheels. Like it was said in the earlier posts, you will probably want to keep it 18" and below to maintain a decent ride, but I will be very interested to see what you do. I plan to put bigger wheels on my Gen III package 4 as I was forced into 15".
    I think all the haters here are need a smug check. [​IMG]
  17. accordingly
    accordingly Member
    268
    63
    Madison, WI
  18. zyonuf79
    zyonuf79 New Member
    38
    RI
    Hook up with some phat 22s and park it like it's hawwwwwwt! lol....all jokes aside, I would be interested in seeing some high quality pics once you make a decision. I wonder if blacked out rims would look good?
  19. wvgasguy
    wvgasguy New Member
    1,255
    185
    a
    I do too within reason. I think no matter what size you get they still look small on a Prius due to the large area over the front wheel well and the large flat slab side. I can't imagine though wanting to drive anything shorter than the 45 series tires. But then again, I've grown past that. Youth can make you bear many things just for the looks.
  20. santaclaraguy
    Oregon
    Thanks for that link! Thats a great start. those being 17"... I think 18" will look perfect.
    I hope to find some more pics before I proceed.
    Agreed... I might get tired of the rough ride... but im not sure. Its been a good 4 years since I owned something w/ low profile tires. I've been running 33" mud tires on my truck for quite some time now and they absorb a lot.:D
    SCG
