1958 VW Bug Powered by Tesla Batteries
Discussion in 'Tesla' started by KennyGS, Jun 3, 2019.
  1. KennyGS
    KennyGS Senior Member
    1,243
    1,044
    Keystone State
    49,397
    wow, that's cool. people are amazing
    who's the guy to the right of nye, looks familiar.
    says no donation necessary to enter, but i can't find it
  3. 3PriusMike
    2,964
    2,316
    Silicon Valley
    I don't know why people get all excited about a car like this.
    It isn't as safe in a crash as a Tesla.
    You'll never be able to get any real maintenance done on it...except tires and wipers.
    I'll probably get banned from the forum...but I never like the VW bugs.
    Mike
  4. Leadfoot J. McCoalroller
    7,138
    6,685
    Pennsylvania
    2018 Prius c
    LOL, you don't get maintenance done on those. You do it yourself. It feeds on the blood shed from your knuckles as you rebuild it daily.
    Fun and mildly dangerous (y)
    #4 Leadfoot J. McCoalroller, Jun 3, 2019
    jerrymildred likes this.
  5. KennyGS
    1,243
    1,044
    Keystone State
    Trollbait and bisco like this.
  6. bisco
    49,397
    'don't want you to read':cool:
  7. Montgomery
    Montgomery Senior Member
    2,254
    2,238
    Orange County, CA
    KennyGS likes this.
  8. Trollbait
    11,514
    Zelectric has other classic VWs and Porsches that they are converting.
    ZELECTRIC MOTORS — available
    This company has a lovely Bronco conversion.
    Zero Labs Automotive | Gallery — Zero Labs Automotive | Premium Classic Electric Vehicles
    What other maintenance is there? Inverter coolant?
    There really isn't anything in an electric drive train to 'maintain' in the manor of an engine and transmission.
    They do use the original manual transmission. So the clutch might need to be placed, but you also don't need to shift it to drive it. With an electric motor, there is enough torque to start in fourth.
    The cars have regen braking, so brake pads will last longer.
    When, or if, you need to replace brakes or clutch plates, the Superbeetle was in production up to 2003 in Mexico. Front disc brakes were even standard since 1995. So parts are readily available, and any basic mechanic can do the work if you don't want to.
  9. Leadfoot J. McCoalroller
    7,138
    6,685
    Pennsylvania
    2018 Prius c
    • Pumping up the spare tire; it provides the pressure for the windshield washer system. A step valve cuts the flow at a predetermined point to keep you from running the spare flat but you still have to charge up the tire pretty often.
    • Wheel bearing repack was every 30k miles on those, iirc.
    • King-pin type front axle will have many lube points. Even if it were updated to the new type it would still have a few.
    • All brake shoes were manually adjusted in those, and single-system hydraulics means you want to get them checked often.
    (I had a '59 that tried to kill me dead a lot)
    Trollbait likes this.
  10. Trollbait
    11,514
    That's one way of ensuring the spare is ready in case needed.
    The one '65 at their site with build photos showing the brakes had the front discs; I'm guessing this is a common up grade for classic Beetles still rolling. Regen braking is going to be on the rear axle.
    I've repacked wheel bearings on a 2000 Ranger. Getting to the adjusting screw on drum brakes can be tricky.
    It may be messy and require patience, but none of those maintenance items require advanced knowledge or skill. Cars of that era were expected to require regular work on them, and they were designed with that in mind. Replacing the engine with a modern motor(Zelectric uses Tesla ones in the Porsches) eliminates most of the 'harder' maintenance.
    PS: No one tell @bwilson4web they do VW Bus conversions.
  11. bisco
    49,397
    there's poly no longer a spare.
    my brothers porsche had the spare tire ww washer configuration. proof that germans don't need a reason why, just if they can
  12. Trollbait
    11,514
    Fair guess, but wrong.
    No more cargo space though.
    But it is a classic car with maybe 100 miles of range.
    Sounds like the company upgrades a fair bit of the car beyond the drive train; brakes, suspension, electrical, etc. They don't touch the chassis, except for a couple holes for cables, so the car could be returned to original if desired. It is also still air cooled, so no inverter coolant.
    It’s Zelectric: Why This Volkswagen Beetle Could Be The Perfect EV Classic • Petrolicious
  13. bisco
    49,397
    toyota, take note.:cool:
    el Crucero likes this.
  14. hill
    8,159
    .... yea ... because it won't need any
  15. bisco
    49,397
    maybe you have to be over a certain age to appreciate it...
