1nz-fxe Prius engine long block swap options
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by JJP, Jun 12, 2021.
  1. JJP
    JJP Junior Member
    Los Angeles
    Hello my 2006 prius has 264,000 miles on it. I got it at 240,000 miles on it burning 1quart of oil per 400 miles. (It had gone 40,000 miles with out an oil change just top offs)
    and a check engine light on for misfire on cylinder 3. The spark plug for cyl 3 was oil fouled and I replaced all of the with Iridium plugs and replaced the PCV valve after that dropped the burn rate to 1quart of oil burnt off per 1,000 miles and the check engine light did not come back until 20,000 miles later with scheduled synthetic oil changes.
    As an experiment after noticing the cylinder #3 oil fouled again I sprayed into the cylinder “CRC GDI IVD Intake valve and turbo cleaner” which claimed to have the highest % PEA detergency. I jacked up the rear of the prius because the engine is tilted back and I wanted it to be level so the fluid would cover the rings evenly, I sprayed into the cylinder every hour for 5 hours and let it sit overnight. I thought I would be a good Idea to turn the crank back and forth but didn’t do it. Next morning I vacuumed any exes fluid in the cylinder and installed a new iridium spark plug and did an oil change, filling the oil filter with Seafoam additive.
    Results; I commuted 200 miles round trip once a week keeping an eye on the oil before and after the trip. The oil burn was minimal to the eye totaling under a quart per oil change at 3000 miles. But the check engine light for cylinder 3 misfire was still showing up after a 2 mile trip to the gas station and parking the car for about an hour before driving 100 miles to complete the round trip. It always happened like this. I stoped reseting the check engine light so it was lit and after doing a Italian tune-up the check engine light turned off and stayed off for months with minimal oil consumption.
    Now it’s burning about 2 quarts per 3,000 miles and the check engine light keeps coming back about a week after I reset it.
    I saved up to get a JDM import low mileage engine (I’ve done this with many of my past vehicles like a 97 camry that went to 400,000 mi after the original engine was replaced with a JDM at 200,000 miles and it was totaled in a rear end colition) but all the JDM importers here in Southern California are out of stock on the 2nd gen prius 1NZ-FXE they have plenty of the Prius C 1NZ-FXE from ‘12-‘19.
    I know this question has been asked before (I read that whole thread). I am taking about using the long block from the C and bolting all the stuff from the 2nd gen. That is the big question will all the stuff bolt on? The bracket that holds the mechanical water pump in the 2nd gen will it bolt up where the bracket that holds the electric pump. Intake manifold and exhaust? Transaxle bolt pattern? I know someone said they bolted up a Yaris engine to a 2nd gen prius and ran fine so it’s likely.
    Why finding out if the 1NZ-FXE from the C would work in the 2nd gen is important to us 2nd gen owners? Possibly piston oiling improvements reducing future oil burn. The timing chain is improved. More lower mileage engines available.
    I don’t know if I’ll find out these answers first hand. I will try the intake valve cleaner on that cylinder one more time and replace the spark plugs with double platinum this time and hopefully get good results for a few months until JDM engines are back in stock. If a prius C lands at one of the many pick your parts in the L.A. area I’ll get the block and start doing some hands on comparisons between the two engines.
  2. Rmay635703
    Rmay635703 Senior Member
    2,590
    1,608
    Somewhere in Wisconsin
    2013 Chevy Volt
    Wrong forum
    unless your considering a 1.8 Prime into your Gen 2
    From what I remember a bunch of wires and connection points changed from Gen 2 -C
    So unless you want to be the first to repin and change out a bunch of stuff likely no dice
    there are several other posts on this subject that went no where feel free to take a search
  3. Trollbait
    11,495
    The Prius c uses a 1.5 L.
  4. Samuel Williams Jr
    246
    Dayton NV
    Ugh, to late now? But why would you buy a car that had not had an oil change in 40,000 miles?
    That aside an engine "swap," can add a lot more complexity to an engine R&R. I would not do it, but that's me. Why try something that may not work?
    The money would be better spent having a "Good Machine Shop," rebuild what you have got. As long as the cylinders are not wildly out of tolerance? It could be rebuilt and you know it works, in your car. :)
    But to be fair, rebuilding an engine is often more expensive than replacing one. So there is that,
  5. dolj
    dolj Senior Member
    7,627
    3,848
    Wellington, New Zealand
    Before going the swap/rebuild route, I just had the thought you might do the piston soak on the three other cylinders, seeing as you had a good result with cylinder 3. Did you (or would you) consider that?
    This is exactly the reason to do a swap. The complexity of rebuilding an engine compared to swapping the engine is a lot less. A mechanic I know does not do rebuilding anymore as he can source good low-mileage engines and swap them in. He doesn't even do a rebuild on his own cars (he buys to fix up).
  6. Samuel Williams Jr
    246
    Dayton NV
    I would agree with you "if" the OP was asking about like for like. Gen 2 motor into a Gen 2 Prius. But she was asking about a Prius C motor into a Gen 2? That is not like for like.
    If one is contemplating doing that or having it done? Then one had better be prepared to answer/solve all none stock issues that come up. I've done it in the past.
    92 Tercel SOHC 3ee (oil burning pig) to a JDM 5efe distributor less, no return fuel line , motor it needed a new/different engine harness and ECU, and a Distributor. I took care of the "Detail's," the Shop did the heavy lifting. It was a generational swap not like for like, more complex.
    The OP also said they couldn't find a 2 Gen engine? I don't know where they were looking? But here is one source for a used engine.
    Search Results
    And E-Bay of course.:
    Complete Engines for Toyota Prius for sale | eBay
    Also there are remanufactured engines which are generally speaking, about twice as much as a used engine but they tend to come with warranty's.
    LKQ Engine, Rebuilt Engine Toyota and Toyota Transmission Remanufactured, Rebuilt Engines And Rebuilt Transmissions For Your Cars, Trucks Engine, Diesels Engines, Boats Engines
    There is not much "need" to do a Prius C motor into a Gen 2 unless, you already have one and want to be "different?" :)
  7. Crash-Law.com
    Crash-Law.com New Member
    Redondo Beach Area
    Thanks for you question, I am interested to learn what the answer is ?
  8. PriusCamper
    PriusCamper Senior Member
    11,055
    4,498
    Pacific Northwest, USA
    Please find out what the error codes are that warning lights have stored... Also doing a compression test will be a wise next step. But given the history of the engine, buying a low mileage replacement engine for $500 is probably where you'll get the best results.
    Samuel Williams Jr likes this.
  9. JJP
    JJP Junior Member
    Los Angeles
    Thanks DOLJ best response so far
    I did soak all pistons at the time but left that out because the post was getting really long.
    Also I was mistaken on my oil change intervals not 3,000 but 5,000 miles so months after this first experiment It’s burning about 2 quarts every 5,000 miles, I’d be ok with that if not for the check engine light for cyl 3 accompanied by oil deposits on the plug.
    I agree, I decided long ago never to have an engine or transmission rebuilt. I’ve known people who have spent thousands on rebuilds only to have them break in to pieces a year later with warranties not worth the paper they are printed on.
    I have bought low mileage JDM engines and transmissions localy in Los Angeles, because of harbor back ups they are out of stock. I not just looking for any used engine. I’m only buying JDM from my trusted source They may be back in stock soon.
    If they are back in stock at my trusted seller I will buy the correct engine for the 2nd gen. But I will still find out if the long blocks between the 2nd gen and C are interchangeable. Sure there will be different pin outs for sensors but If every thing fits in the same holes. Like all the other times I’ve changed and engine and bolted all the different things from one to the other.
    For now I’ll do another piston soak, oil change and this time I’ll put in the double platinum spark plugs as I suspect the double platinum arc points will burn off oil residue better and not misfire.
    The reason I bought this neglected prius was to get some hands-on experience on the marvel of engineering that is the Gen 2 prius and what a great decision that was this has been a great car.
  10. Rmay635703
    2,590
    1,608
    2013 Chevy Volt
    Personally because PRII motors are all over the map regardless of miles if you have more time than sense get the cheapest good running one you can find don’t worry about miles but hopefully can validate the heads and compression before pickup
    Normally these type of motors are $75 but it appears like everything they have gone up in price
    Even with high miles if you can validate it’s a runner with no head gasket or leak down issues you should be fine for the rest of your ownership, if you can find one with lower miles that isn’t rediculously overpriced fine but I wouldn’t invest too much effort if your good at swapping like for like
    Gen II is definitely not the same needy variety as Gen III
  11. Samuel Williams Jr
    246
    Dayton NV
    Agree like for like is not a big deal. But that is not how the OP started this thread, just saying.
  12. Rmay635703
    2,590
    1,608
    2013 Chevy Volt
  13. JJP
    JJP Junior Member
    Los Angeles
    Apparently initially I did post it in the wrong section, I could have sworn I put it in the 2nd gen main forum.
    Anyway, I would love to get a rolled-over prime and swap everything into an 2nd gen MR-2. Or even better into the shell of BMW i8. But that’s a fantasy build.
    It would be interesting to see some full build videos of prime swaps into cool 90’s Japanese cars.
  14. Blutoya
    Blutoya Junior Member
    Anaheim, CA, USA
    My 09 is burning oil still after various treatments eventually I’ll be replacing it
