1st Prius Failure... but no runaway...
Discussion in 'Gen 2 Prius Main Forum' started by B. Roberts, Apr 11, 2010.
  1. B. Roberts
    B. Roberts Hypah Milah! Ayuh.
    691
    212
    used to be "Glacial" Maine and now FL
    A little dissapointed... the pump went out at 78,000 mi. It started to sound a bit weak and wobbly. The last month it was getting much weaker and figured that it would quit any moment. Finally got a check engine light just at oil change time.
    I had the pump replaced, but I do have questions.
    If you didn't replace the pump after it failed... I imagine the coolant would just stay out of the thermos bottle when the car was shut down? At start up the engine warming would take a little longer... enough to lower MPG?
    If the pump stopped working after the thermos was filled, would the coolant just stay in there? How much does the "thermos" hold? Enough to cause a cooling problem if it remained in the bottle?
    I still keep it chained up in the garage at night... just in case.:wacko:
  2. Patrick Wong
    18,200
    6,493
    The CHRS canister holds around 3 quarts of fluid.
    If the pump didn't work, the fluid in the canister would become cooler than it otherwise might be. The position of the valve that controls flow of coolant to that canister depends upon the extent to which coolant is required to heat the cabin heater core. Hot engine coolant may continue to flow into the canister while the engine is running. The fluid in the canister will be hotter than ambient temp but cooler than if the pump functioned upon engine shutdown.
    I understand that the motivation for the CHRS system was to reduce emissions during the initial warmup period and to help 2G Prius qualify for the AT-PZEV designation. I doubt that it has much effect on mpg.
  3. RolfS
    RolfS Junior Member
    45
    Just to clarify. The water is in the engine block and the "thermos" at the same time. The only thing the pump does is to exchange the colder water in the engine block with the "thermos" warmer water when first starting up after the car has been sitting awhile. What was in the engine block goes into the thermos and what was in the thermos goes into the engine block. If you run sufficiently long enough then the circulation valve is set so that water is circulating through the engine block and thermos (and radiator) at the same time with the water being at the same temperature throughout. If that is the case it will just shut the valve to the thermos when you turn off the car and not even do any pumping. There are sensors that determine whether the engine block or thermos water is hotter, upon which it bases its decision on how to circulate the water with the pump.
  4. B. Roberts
    691
    212
    I had read that the warm water in the thermos was pumped to the engine to help emissions at start up. On our Prius, I've noticed that the pump runs about 3 to 5 minutes after shutdown, and it seems to run every time that we drive, no matter what the distance.
    Just thought I'd mention this little observation. What kind of longevity should we expect from this pump?
