1st tank hit 53.1 mpg, HAPPY!
Discussion in 'Gen 2 Prius Fuel Economy' started by mschrank, May 9, 2007.
  1. mschrank
    mschrank New Member
    Just fueled my Red 07 Touring, pkg 6 for the 1st time. 13 days old.
    Was down to 1/4 tank. 430 miles. Mileage had been climbing
    continually, using Pluse & Glide as needed and reached 53.1 mpg when I stopped at Shell this AM.
    Couldn't be happier! Just gave her a coat of wax. She's gleaming in the Colorado sun.
    Question. Taking trip to Wisconsin end of May. Probably take I-80 most of way. Should I be concerned?
    ie What if Prius breaks down? My wife is worried no one could fix if not near a Toyota shop. Thoughts.
    MHS
  2. dmckinstry
    dmckinstry New Member
    1,034
    Cheney, WA (Near Spokane)
    <div class='quotetop'>QUOTE(mhs @ May 9 2007, 10:50 AM) [snapback]438373[/snapback]</div>
    I'd suspect the odds of it breaking down are practially nil. Granted, if you had problems near a small town, you might have trouble finding a mechanic to handle it. My Prius has 47k miles on it. I certainly wouldn't be afraid to drive it completely across the country. In fact, next Christmas I plan on driving from Washington (state) to Florida and back. However, I will have on new tires by then.
    Dave M.
  3. mschrank
    mschrank New Member
    <div class='quotetop'>QUOTE(dmckinstry @ May 9 2007, 12:20 PM) [snapback]438447[/snapback]</div>
    Thanks for response. I agree with you that it is highly unlikely for a new Prius to need repairs.
    To be safe I'm trying to put about 1,000 miles on her before the trip, thinking 'if' anything were wrong from factory, that it would show up sooner than later.
    Sure love this car.
    It replaced a 2,000 Chrysler 300M, which was a very good vehicle w/52,000 miles. Didn't want to press my luck beyond that as I've had Chryslers & GM products that would start going south after 50m. So after much consideration went for Prius Touring. What a fine piece of technology!
    MHS
  4. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    Congrats! I only got a tank like that once. :)
    I do seem to be having an easier time staying about 48mpg now that the temps came up and if I could stop driving after the temps drop below 60deg I'm sure 50+mpg is doable.
  5. kdk84
    kdk84 New Member
    113
    Michigan
    congrats on the 50+ tank.
    As a new prius owner myself (bought one roughly 3 weeks ago) my first tank I took down to half way and averaged 55.8 MFD MPG and today I just took a 184 mile trip on a fresh tank of gas and averaged 58.7 MFD MPG!! My car only has 407 miles on it so I'm hoping that once it is more "broken in" I'll reach a 60 MPG tank!
    This car is absolutely crazy! haha it's great.
  6. mschrank
    mschrank New Member
    <div class='quotetop'>QUOTE(kdk84 @ May 9 2007, 05:30 PM) [snapback]438679[/snapback]</div>
    It's so neat to see mpg continue to improve as Prius breaks in. It is fun!
    FYI. I ordered and had body shop install side mouldings, look great (just like factory) and add some protection. Just thought I'd mention. Prius Chat Accessories.
    MHS
  7. wb9tyj
    wb9tyj 2017 Prius Prime Advanced
    389
    94
    Indiana and Nevada
    we went from indiana to california and back and plan on doing it again this summer...not a bit of problem...
    after 60000miles...no problems...so i wont worry about alledged breakdowns...its a lot more reliable than any thing else ive owned over the last 30 years...
  8. ystasino
    ystasino Active Member
    793
    50
    Tucson, Arizona
    <div class='quotetop'>QUOTE(wb9tyj @ May 9 2007, 10:43 PM) [snapback]438770[/snapback]</div>
    Are people posting the computed mpg? If so my first tank was only 47.4 :(
  9. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    <div class='quotetop'>QUOTE(ystasino @ May 9 2007, 10:23 PM) [snapback]438864[/snapback]</div>
    No, generally you want to stick with the MFD. The gas tank expanding and contracting can mess with your head too much. ;) Some use both methods and average them out in the long run.
    47mpg is pretty normal or at least it used to be until the last couple days where new posts are popping up everywhere with 50+mpg averages. They may also be driving on a lot of rural roads or inner city which can net some pretty nice numbers. Mainly freeway driving seems to hurt my milage.
    Summertime heat and gas formulas may be helping out a bunch in a lot of these cases. I know once temps get over 65deg or so my milage shoots way up.
  10. FireEngineer
    FireEngineer Active Member
    1,247
    124
    SW-Side of Chicago, IL
    <div class='quotetop'>QUOTE(mhs @ May 9 2007, 12:50 PM) [snapback]438373[/snapback]</div>
    Just make sure to pump up your tires a little bit more than you normally do.
    Wayne
  11. Darken
    Darken Active Member
    553
    49
    PA Dutch Country
    <div class='quotetop'>QUOTE(ystasino @ May 10 2007, 01:23 AM) [snapback]438864[/snapback]</div>
    I calculate it both ways and in most cases the MFD is higher due to the 'bladder' in your gas tank messing with the actual fuel consumed. I know its been posted by those in the 'know' around here that overall the MFD is very accurate in its postings of your FE.
  12. dmckinstry
    1,034
    Don't feel bad. My first tank was more like 45 mpg. I don't remember now. My first long trip. WA to CA was more like 50 mpg though. But I purposely went the coast route to avoid higher speeds. And this was in August '05.
    Dave M.
