1st time oil change
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by mr estrada, May 24, 2013.
  1. mr estrada
    mr estrada Junior Member
    43
    Hey guys,
    newly purchased 2013 prius i'm about 3,200+ miles in and was wondering when would a good time be to get my 1st oil change?
    just wanted to know if i'm around the ball park range in getting one or not.
    thanks!
  2. jgilliam1955
    368
    102
    Williamsburg, Virginia
    What does the book say?
  3. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,476
    1,552
    Bay Area
  4. Sfcyclist
    Sfcyclist Senior Member
    1,621
    375
    SF, CA
    You mean doing this on your own and outside of covered maintenance? A few threads and results are 10k is not an issue.
  5. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    A lot of people like to make the first oil change before the recommended 10k miles. 5k is reasonable for an early change.
  6. mr estrada
    43
    Dang 10k that seems a bit a long for a 1st time oil change.
    Thanks.
  7. NutzAboutBolts
    1,476
    1,552
    Bay Area
    I did it at 10k, nothing wrong with my engine. That's my opinion, you can do whatever you want with it.
  8. Jonny Zero
    Jonny Zero Giggidy
    1,388
    351
    Austin, TX
    Me too.
    1) Engines are built to tighter tolerance today than before.
    2) Oil is much better.
    3) But, old habits die hard.
  9. Former Member 68813
    3,524
    981
    US
    One thing I noticed that when people start another one of those "when to do first oil change" thread, they are not asking for answers, but rather confirmation of their preconceived believes. Sorry, couldn't resist.
    NutzAboutBolts likes this.
  10. NutzAboutBolts
    1,476
    1,552
    Bay Area
    I agree. There's too many threads open with this topic, may we close this please. Thank-you.
  11. Mendel Leisk
    38,702
    Let people know your location would help.
    Just North of the 49th parallel in Canada the interval is 6 months or 8000 km (5000 miles). Go a few km's south into the States, same climate, same car, and the interval is 12 months or 10000 miles. Being in Canada, I go with the first, but even if Toyota increased it I'd likely stay with the shorter interval: it costs about $30~40 for the parts, and takes an hour or two, if you DIY.
  12. dragonfly13
    dragonfly13 Junior Member
    I felt the same way about early oil change. I called the dealer and was told if it makes you feel better get it changed early. It's a waste of money though. The new oil Toyota uses is really made for 10k miles with no problem. Yes, old habits do die hard.
  13. jhinsc
    jhinsc Senior Member
    1,167
    259
    South Carolina
    Why? Please explain.
  14. MPGnutcase
    MPGnutcase Active Member
    579
    114
    Chicago
    10k is from Toyota and the dealer, I was told Toyota dumps in special additives at the factory for the first break in period and you want to keep it in at least till 7500..............:)
  15. Mendel Leisk
    38,702
    ^ Then, in Canada, where Toyota says to pull the drain plug at 8000 km (5000 miles), we're draining those "special additives" prematurely, LOL.
  16. mr estrada
    43
    sounds like a plan, thanks!
