1st time problem: Engine would not shut off!
Discussion in 'Gen 2 Prius Main Forum' started by local_host, Dec 16, 2007.
  1. local_host
    local_host Junior Member
    75
    Have a brand new '07 Prius: This afternoon I went to move my car onto the street and waited for the engine to shut off then go into 'stealth' mode. It never did. I even drove up and down the street for a minute just to see if that might do anything. I sat in the car and waited for about 5 more minutes, still didn't shut off. The Energy Monitor didn't even show and activity and the heater/AC was not turned on.
    Anyone else ever have this problem? I hope it's not a sign of things to come. When I turn on/off the car I notice that the 'maintenance required' light briefly flashes, then goes off, as the engine starts. I actually can't remember if this happens all the time, because most of the dash lights briefly light up as the car first turns on.
  2. TonyPSchaefer
    14,816
    2,499
    66
    Far-North Chicagoland
    First of all, the MAINT REQRD light flashing is an indication that it has been 4,500 miles since your last oil change (or at least since the light was reset). Give it time and the light will stay on rather than blink.
    Is there any particular reason that you were waiting for the engine to shut off? It sounds like you spent about ten minutes just sitting in an idling car. It sounds as though you had just started the car as opposed to having just driving for a while. If this is the case, you need to understand that the engine will run until it is warm enough to shut down. That can take some time. Since you do not have your location entered, we don't know what the ambient temperature was at the time.
  3. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    Tony's beating around the bush, but the answer is that it was cold...even though you didn't say where you're located or what the temp was I'm quite confident of that.
    Most likely the battery was very cold and when that's the case the ICE will often continue to run.
    The only other possibility that comes to mind is that you may have been in B or N...in those cases the ICE won't shut down. But I'm sure it's b/c the car was very cold.
  4. Neicy
    Neicy Member
    834
    Wakefield, MA.
    The engine, when cold, will run until it is warm and comfy. This is the reason a lot of us block the grill and use an engine block heater (EBH) during the winter.
    The Maint. Required Light flashes briefly once every time you start up along with other lights in that area to show they are working properly. When you get close to 5000 miles since the last reset it will flash slowly for a minute or two indicating will you need an oil change soon. When you reach 5000 miles since the last reset the light will remain on until it is reset again when the oil is changed. This is what I have experienced.
    BTW Congrats on your new car. It is an amazing vehicle and if you look and listen too closely it's easy to think there's something "not right" with it when you first get it because it is so different than your standard gas-only engine.
  5. local_host
    75
    WOW, thanks for the quick replies... I'm in TX and we did just have a major cold front arrive so I think the engine being cold probably explains it. I just can't recall that it ever happened before and was a bit alarmed. Also seeing the maintenance light flash on enforced my worry, since I'm not near 20,000 just yet (15k+ since Jan. yup I travel ALOT;-)).
    By the way, I was waiting for the engine to shut off because normally it would after the amount of time I was in the car- but it didn't. Which gave rise to me thinking there was something "wrong". I'm kind of OCD and wanted to make sure everything was working properly so I tried to wait for it to shut off and wanted to see how long it would take.
    Funny thing is, I turned off the car, then back on, and the engine shut off after the "normal" period of time. It's like the computer needed to reboot.
  6. richard schumacher
    7,664
    1,043
    United States
    Well, duh: you had just spent ten minutes warming it up.
    Go, and sin no more :_>
  7. GigaTigga
    GigaTigga New Member
    84
    Nebraska
    I'm new to the prius bunch, but i know when its chilly out my prius doesn't shut off for near 20 minutes (~20F). I got mine a few days before winter hit, so i know i can get better mileage than i currently am, but i give up a few MPG to not freeze my tail off on the drive to work!
  8. siliconhybrid
    siliconhybrid Member
    121
    Bay Area California
    correct me if i am wrong.
    I believe by turning on the heater, the engine will have also turn on, not all the time, but most of the time, especially in winter cold season.
    question is, when you were idle for 5 or 10 mins, did you turn on the heater too?
