2 battery vents backseat
Discussion in 'Gen 4 Prius Main Forum' started by Squished catfish, Jun 14, 2024.
  1. Squished catfish
    Squished catfish New Member
    San Diego
    The one on the right side I see mentioned often but I also have another vent in the middle. No one has commented about this on Reddit so looking here. It is not in the owners manual. I notice the middle vent gets quite warm. I want to know why I'm having such a hard time finding out about the middle event. And why does it get warm?. No guesses. Only comment if you really know.
  2. Tideland Prius
    16,195
    If you don't want people to guess, a photo would be helpful.
    Brian1954 likes this.
  3. Squished catfish
    San Diego
    I know. I tried a dozen times to upload a photo. I don't know what I'm doing wrong.
  4. Squished catfish
    San Diego
  5. Squished catfish
    San Diego
  6. Tideland Prius
    16,195
    I see the photos now.
    The thing is, I don't remember seeing that on our 2016 so it's baffling to me. The location of that photo makes it seem like it's just a vent. (Not necessarily an exhaust vent. Definitely not intake as the intake is the one shown in the manual). The reason why it's warm is because the HV battery is located under the rear seat. That silver piece you see through the vent slats is the battery casing. It's likely Toyota made a change for 2017 and newer but didn't bother to update the manual. (I checked a 2022 manual too and it has the same pictogram as the one you attached).
  7. Squished catfish
    San Diego
    I would like to know why the vent in the middle was determined to be added to my 2017 Prius. I'm surprised I can't find the answer on the internet. I don't like having extra heat enter the cabin. It's summer. I don't understand why they couldn't direct the hot air to outside.
  8. KMO
    KMO Senior Member
    1,562
    439
    Finland
    2023 Prius Prime
  9. Squished catfish
    San Diego
    Ok thanks. I drive on hills often. I notice anything sitting there, like a water bottle, will get quite warm. I would have thought Toyota would have a better way of expelling heat from the battery. And I'll try not to spill my water there or else I'll have to go to the dealer. Says manual. Yeah right .Geez.
  10. bisco
    49,693
    that's a prime thread, do you have a prime?
  11. Mendel Leisk
    38,873
    Those are inlets, pulling air in, to be exhausted out the vents at rear corners of hatch area?
  12. KMO
    KMO Senior Member
    1,562
    439
    Finland
    2023 Prius Prime
    I think this may be a non-plugin that has a panel from a plug-in. On the plug-in, that should have a filter and lead to a plastic duct for a cooling inlet to the charger. OP has the non-plugin manual and seems to be seeing the non-plugin battery there.
    Production error? Deliberate part substitution? Sloppy repair?
