2 codes help please
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Steve 72, Jan 7, 2026 at 2:03 PM.
  1. Steve 72
    Steve 72 Junior Member
    Maryland
    Hi all.. 07 Prius. VSC Triangle of death and brake lights illuminated. Went into limp mode immediately. Pulled HV battery and all cells are 7.7-7.8. 2 codes are stored C1259 and C1310 Hv battery is good and am stumped now. Any help to fix this issue will be greatly appreciated. Thanks for your help and time .
  2. Tombukt2
    Tombukt2 Senior Member
    13,106
    2,352
    Durham NC
    Check your 12 volt ....wheel sensors etc.. brake issues is what ya got
  3. Brian1954
    Brian1954 Senior Member
    2,302
    915
    South Central PA, USA
    Those two codes just mean that the hybrid vehicle control ECU has a code. The scanner that you are using is not capable of communicating with that ECU. So, you need a more capable scanner to read all the codes that your car is trying to tell you about.
    Where in Maryland do you live. If it is close by, I may be able to help.
