2 dollar way to solve int. light dimness
Discussion in 'Gen 2 Prius Accessories & Modifications' started by problemchild, Nov 6, 2008.
  1. problemchild
    problemchild New Member
    429
    36
    The dome bulbs have the same base as a brighter 921 bulb. Go to any auto parts store and buy the 921 LL bulbs/2 pack for 1.99-2.99. Its a 19w bulb to replace the 5w bulbs that are installed at the factory. There are 3 bulbs in the overhead. I pulled out the old bulbs and stuck the new 921's in. Wow the car is bright inside now. You can also replace the middle overhead and back bulbs too with double bright wattage bulbs for another couple bucks. They are a different base but are easy to locate it you have the bulbs in hand. The wattage is on the base of the bulb. No expensive LED mods needed.
    You go from a combined 15 watts to a whopping 57 watts which is the same as a car headlight. It is very bright now. I no longer need a flashlight to find things in my car when it gets dark.
  2. rigormortis
    rigormortis Active Member
    1,340
    26
    san jose, ca
    how long have you had the brighter 921 bulb? i might try that.
    the only word of caution is you do not want to blow the dome light fuse, it runs other systems, and a lot of rebooting a prius is just reinserting the dome light fuse
    the dome light fuse is good for 15a, and it runs the audio system, interior lights, smart keys, gauge and meters, turn signal lights, luggage room light, and part of the clock
  3. rigormortis
    1,340
    26
    san jose, ca
    further research also states that part of the theft deterrent system and power door locks is also dependent on the dome light fuse
    oh yeah the garage door opener too
  4. rigormortis
    1,340
    26
    san jose, ca
    also, i am not sure about this, and i am not saying it will do it, but running
    higher wattage bulbs might actually burn / melt / scorch the plastic lenses
  5. jelloslug
    jelloslug It buffed right out!
    813
    Greenville, SC
    A 921 equivalent LED bulb would be a good choice. I don't think there would be a current draw problem but there is a very good chance of melting something over time with the 921.
  6. problemchild
    429
    36
    I left them on for 15 minutes (far excedding any amount of time you might have the doors open) and all 3 bulbs were on. The cover got warm but not hot. No fuses were blown. It works great.
  7. Ct. Ken V
    Ct. Ken V Active Member
    535
    57
    Bolton,CT
    Hi,all,
    I'm not sure of the exact bulb # I used to have in my Ford Escort high mount brake light housing. The 921 does sound like the right one to me (whatever it was, it was the one specified in the ownwer's manual). You can't always believe the owner's manual because in one of my other Ford Escorts that I had, the manual specified for the tail/brake light bulb to be a 3157 (with a black plastic wedge style base, which I went out & bought). But the bulbs that were in the bulb sockets in that location in the car were the 1157's (with the round brass bayonet base with the little retainer pins on the side), so I had to go back & exchange them.
    But anyway, every time I took out a burned out bulb from that high mount housing, the bulb had a big, blackened, blister bubble on the side of it (kind of like the old photo flashbulbs of days gone by). The bulb glass had actually melted & deformed from the bulb's own heat (with the additional heat from being enclosed in a small non-ventilated enclosure) & the brakes had never been applied for anywhere close to the 15 minutes that problemchild just said his dome lights were on for. Given my own experience, I would opt for the LED equivalent of the 921 if you want that much more light.
    Ken (in Bolton,Ct)
  8. rigormortis
    1,340
    26
    san jose, ca
    try 8-24 hours please
    i am basing that on my real world experience of coming back to my car
    and finding out i left the map lights on!
  9. problemchild
    429
    36
    I have a 15 minute timer on my dome lights. So I cant help you there.
  10. hill
    8,036
    If you really want to be everyone's hero, you'd find a way to get the dim stearingwheel lights brighter. Every other light on the Prius has already been modded and talk about, ad infinitum.
  11. problemchild
    429
    36
    Steering wheel lights are fine for me.
    No one has done a 2.00 light mod, only expensive LED mods.
    My mod was a 2 dollar mod.
  12. xsmatt81
    xsmatt81 non-AARP Member
    522
    Vegas
    cool stuff. Think I will go pick some up.
    sounds a bit to bright imo. I wonder if there is a bulb in the middle say 12w
    thanks for the post
  13. EZW1
    EZW1 Active Member
    722
    Phoenix, AZ
    2016 Prius v wagon
    Four Touring
    One thing you might want to consider with a brighter bulb is the heat factor. That is to say if you leave the dome light on accidently for an extended period of time, you not only will kill the battery but you might also melt the plastic around the bulb. By increasing the illumination 4-times, you are also increasing the heat by the same amount - and since the bulb is in an enclosed space, the heat buildup bay cause you grief.
  14. rigormortis
    1,340
    26
    san jose, ca
    melting parts of the car was already brought up on page 1 of this thread
