2 mods dashcam/rear and rear fog
Discussion in 'Gen 5 Prius Accessories and Modifications' started by BlueZebra, Dec 26, 2024.
  1. BlueZebra
    BlueZebra New Member
    Richmond
    2024 Prius
    LE AWD-e
    As above, seeking advice.
    24 LE AWD - no fog switch or lamp I can find
    The rear fog: so far the plan is a 'bar' over from the license screws. Tag a feed, run 2 conductors up to the left hand sill trim, switch in hole (at left hand when dropped), and then back to lamp.
    It is LE, I do not know higher trims.
    Is it worth investigating / then flashing and installing a factory system (for front fogs and tag feed from there)?
    Or just implement my plan?
    Suggestion for feed point from rear?
    Do any existing lamp systems 'rebel' at 4 more milliamps?
    Front dash cam: Is it acceptable to 'sticky' to the dotted area? Is it GPS / radio transparent?
    Rear (dash) cam Looks like it will have to go on the hatch glass (high near hinge) or maybe on hard trim for glass. Any suggestions for wiring (needs to hinge / flex for hatch swing).
    Any experience?
    THX!
  2. priusasa
    priusasa Junior Member
    79
    34
    2023 Prius
    I need to suggestion about rear dash cam too. Recently I bought Fitcam front and rear. The wiring for rear is you can just stuck the cable in between panels and plastic rubber (Top of the doors to all the way back), but it creates little gap. I believe if you just leave it there for a long time, that gap will be permanent.
  3. priusdriver223
    82
    32
    Lala Land
    2023 Prius
    XLE AWD-e
    IMG_0788.jpeg IMG_0789.jpeg IMG_0790.jpeg Hey there! I run my dashcam through one of the usb slots i have that’s being powered by my mirror tap, i tuck the wires along the side of the housing for the rear view mirror and then to top of the interior liner onto part of the B pillar and then I run it through the entire side of liner until it reaches to the trunk area and I have it set up right on top of the trunk window. I left enough slack on the cable so it won’t interfere with the opening of the trunk, even at max height.
    As for your fog light or lamp, I don’t know if I’m understanding it correctly but isn’t it easier to just connect it directly to the 12v battery in your trunk for power? You can find your desired lightbar or fog lamps, the switches they come with all have a fuse with a relay, if you do not like the switches they give you, you can always swap them out for another one. As for the wiring, you can definitely drill the section behind your license plate holder to route it all the way up your trunk and then to the front of the car and mount your switch there.
    Cheers!
  4. Perfectpacman
    Perfectpacman Junior Member
    84
    22
    United Kingdom
    2024 Prius
    ----UK----
    Couldn't you attach the rear dash cam directly to or underneath the roof lining and not directly to the rear screen?
    That way you'll avoid that length of cable dangling.
    Because the rear ones are typically very light, it's quite straightforward too.
  5. priusasa
    79
    34
    2023 Prius
    How is that rear camera even stick to glass, I tried bunch of double sided tapes, even with expensive ones, but no hope. Also, when you put the cable all the way back to front, do you have any gap for the panels because of that cable? Because some areas have gap when I stuck the cable there. Did you need to remove any component to put cable?
    #5 priusasa, Dec 31, 2024
  6. Perfectpacman
    84
    22
    United Kingdom
    2024 Prius
    ----UK----
    You must be using the wrong tape.
    3M VHB (Very high bond) will support over 5kg.
    Make sure that the glass area is scrupulously clean, isopropyl alcohol is what you should use in preparation.
    As far as the cable to the rear camera is concerned, be careful where the airbags are situated. The side and curtain airbags are located behind the trim so personally I avoid them.
    I'm using a 622 Nextbase with rear telephoto camera attached. It's not as good as a dedicated rear camera, but it shows any tailgating etc.
    If you had a tap into the tailgate wiring, it can be done that way but you can bet your insurance and manufacturer won't support you if there's an incident regarding electrics or airbag deployment.....
  7. priusdriver223
    82
    32
    Lala Land
    2023 Prius
    XLE AWD-e
    Hey there, my dashcam actually came with Electrostatic mounts for my rear windshield, I simply didn't bother doing it another way since it was sticking well and didn't interfere with anything.
  8. priusdriver223
    82
    32
    Lala Land
    2023 Prius
    XLE AWD-e
    Hey there, you can try "Electrostatic Stickers for dashcam", they're available on Amazon and sometimes even come with your dashcam. Cheers!
  9. priusdriver223
    82
    32
    Lala Land
    2023 Prius
    XLE AWD-e
    Hey there, the gaps are almost unnoticeable, and the only places that it show is between top of the B pillar to your front liner which I actually showed in one of the photos in my previous comment. Other than that, no problems and no big gaps. Cheers!
