2 quick questions
Discussion in 'Prime Technical Discussion' started by dpframing, Sep 3, 2022.
  1. dpframing
    dpframing "Nobody tells me what to do, not even me."
    78
    Chester NY 10918
    2022 Prius Prime
    Hey Primers. There are many experts on this site with alot of valuable info. I just got a 2022 Prime and I had 2 questions which I tried to answer with searches. But inevitably the search leads me down a path of complicated answers loaded with specific info which I don't need or understand. So I would like to ask: can a charge be interrupted? If the car battery is connected but only half-charged, and I have to use the vehicle, is it ok to disconnect? And also, if I do a complete charge (I'm currently getting 28-30 miles per full charge), and I go on a 12-mile trip in EV mode and use up almost half the charge, is it ok to re-charge to top off the battery when I get home? Or does the battery need to be completely discharged before I connect again? If it's ok to do that, would doing that consistently over the life of the car decrease the battery performance over time? Thanks.
  2. john1701a
    john1701a Prius Guru
    12,818
    5,303
    58
    The system is extremely flexible. No need to give it any thought....
    You can stop charging at any time.
    You can resume charging at any time.
  3. Elektroingenieur
    2,515
    3,284
    Three Touring
    Yes. Owner’s Manual (PDF), page 93: “Even if charging the hybrid battery (traction battery) has not been completed, the vehicle can be driven.”
    Yes. Owner’s Manual, page 140, item ③: “In order to drive the next time, charge the hybrid battery (traction battery).”
    See “Capacity reduction of the hybrid battery (traction battery),” Owner’s Manual, page 144.
    drash and schja01 like this.
  4. Mendel Leisk
    41,545
    Consider: would it be that easy, to break your car?
