2 unusual sound need explanation
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Eric Vasaio, Jul 17, 2019.
  1. Eric Vasaio
    Eric Vasaio New Member
    BC, Canada
    2013 Prius Plug-in
    So I've got this 2013 Prius 2 month ago. I always hear these 2 sounds from this suppose to be very quiet car. I tends to think they're just normal sounds but...
    First, humming electric motor sound. Especially under low speed and gentle brakes, I can hear this bee humming sound relatively loud. If you have an old style not well lubricated electric fan in summer time, that's the sound.
    And then, every time, about 1 minute after I shut the car off, there's always a clunk sound from front of the car, maybe from under hood, or maybe from brakes which is really hard to tell. As if two metal pieces get engaged or disengaged.
    Are they normal Prius sounds? thanks for any input.
  2. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    Sounds normal to me
    Eric Vasaio likes this.
    52,393
    i would take it back to the dealer for warranty repair
  4. ChapmanF
    18,550
    Self-test of brake system, couple minutes after power off, every time. If you listen carefully, it's more than just "clunk", but more like "clunk ... clickity squish ... squish clunk".
    Utterly normal.
    Sometimes, it will need to repressurize during the test, so you'll hear the brake pump too ("whirrrrRRPclunk"). Not every time. Depends on what the accumulator pressure happens to be when the test starts. Don't be concerned because you do or don't hear it every time.
    If the car detects any problem, it'll tell you. That's why it self-tests. No news is good news. :)
    Whatever you're thinking, you did not just read this same explanation in some other similar-looking thread. Have you tried getting more sleep?
  5. Eric Vasaio
    BC, Canada
    2013 Prius Plug-in
    Figured out with you guys help. Turns out the first humming sound is the Vehicle Proximity Notification System, and the brake clunk is something auto pressure the brake system. Thanks you all!
  6. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    It’s the awful sound of a spaceship, I do really want to rip that thing out or replace it with the dukes of hazard chase theme song when they’re fleeing a scene. But I’d be in one hellva slow chase, get caught in seconds haha.
