2002 Prius needs new steering rack at 98K?
Discussion in 'Generation 1 Prius Discussion' started by ca02prius, Aug 11, 2009.
  1. ca02prius
    ca02prius New Member
    San Jose, California
    2002 Prius
    This is the second big repair (or third, depending on how you count them) in less than a year, so I'm having some major worries about the trustworthiness of my 2002 Prius. In December 2008, at 90K, I had to have the ECU AND gas tank replaced (diagnosed by dealer; 10K past warranty; $1600). Now, at 98K, I'm told the increasing squeaking/groaning noise made by my steering requires that I get the steering rack and pinion replaced (non-dealer diagnosis this time, as I didn't trust the dealer; $1300). I've had all regular service at the appropriate intervals without any problems at all prior to the 90K problems, and I don't seem to have any choice about the steering gear, but how can I be sure I'm getting a good diagnosis? Is this the beginning of the end? I was really hoping to drive this car for at least 10 years, preferably longer (200K). Am I being unreasonable? How long should this car last, and what are reasonable repairs as my car ages? If anyone knows of a good, honest mechanic in San Jose, CA, I'd sure like to know! Thanks.
  2. Patrick Wong
    18,210
    6,514
    I question the need to replace the fuel tank in 12/08 unless the tech had checked the fuel line pressure and found it to be below spec.
    Regarding your steering gear, if the only problem is noise and you haven't had the steering wheel jerk around by itself, then I suggest deferring a replacement until you have driveability issues.
    Once your Prius is out of warranty, there are several components whose failure will lead to a hefty four-digit repair: transaxle, traction battery, inverter, steering gear, catalytic converter with HCAC chamber, MFD. If you have to depend upon dealer service then you'll be out big bucks.
    In the Bay Area, Luscious Garage in SF and Art's Automotive in Berkeley have strong Prius service reputations.
  3. tochatihu
    tochatihu Senior Member
    9,855
    3,815
    Kunming Yunnan China
    2001 Prius
    If the steering assist 'cuts out' you'll know it, both by feel and the warning on the little TV. But with noise as the only symptom there I suggest you simply have the steering mechanicals inspected by a (any) shop familiar with modern front wheel drive cars.
    If the mechanicals look OK then you can drive w/o concern. At least until Act II.
  4. ca02prius
    2002 Prius
    So, both of you think I should wait until I experience steering problems before replacing the steering gear? Do you think I'll have enough warning to do something? The noise has been so annoying, and frankly, I'm embarrassed every time I turn; it's particularly bad when I turn right and can be heard outside the car (on both sides, says my brother-in-law). I am definitely ignorant when it comes to cars; I just take it in for the scheduled maintenance and expect that it will keep running for at least 10 years!
  5. Patrick Wong
    18,210
    6,514
    If the noise is sufficiently annoying so that you are willing to pay $1,300 to make it go away, then go ahead and have the steering gear replaced now.
    Otherwise, if you can live with the noise, I recommend that you defer the repair until you have driveability issues, such as having the steering wheel twitch violently... The problem will get worse as time passes, so you'll have plenty of opportunity to take action.
  6. ca02prius
    2002 Prius
    Thanks for the advice. Regarding your previous response, since this is probably the beginning of many more problems, would it make sense for me to consider looking at a new car in the next year or two? This hasn't been my practice in the past, as I like to see how many miles I can get on a vehicle, but I'm also less inclined to live with ongoing car problems when I don't have to. I guess I should check into blue book value vs. repair costs...
  7. ca02prius
    2002 Prius
    Well, here's the rest of the story, which I guess I now consider a cautionary tale... I should have taken your advice and not had anything done. But, because the "hybrid certified" folks at the shop, which I can now reveal as Pep Boys, convinced me that I needed the steering rack and pinion replaced, and instead of doing the smart thing and getting a second opinion, I ordered the part and paid in advance, as required (two mistakes here!). Then, after they replaced the rack, I found that the steering was worse than before they replaced it! No more whining noise, but instead, terrible vibrations when turning at slow speeds. So, of course I took it back. They took it to the dealer for recalibration to be told that a new ECU was required with any new steering rack. No more Pep Boys for me!
    But, now what do I do? I took it back to the dealer who told me the steering rack was 'after market' and they didn't have an ECU that matched. They recalibrated the existing ECU and said to see how it goes. It seemed to work at first, but this morning it was shaking again. Any advice? Is this when I give up on the car, or is it worth putting more money into it? If so, what are my options? Anyone know of a good Prius place in San Jose? (Berkeley is really too far, sorry...)
  8. tochatihu
    9,855
    3,815
    2001 Prius
    I am unaware of aftermarket versions of this assembly. Perhaps it was from salvage, or an attempt at a rebuild? As a guess, an ECU can only calm this down if it uses a really long time constant in determining the sensor signals. If the shakes return, I don't have any ideas, other than taking action against Manny, Moe and Jack. Very sorry.
  9. ca02prius
    2002 Prius
    Thanks. It seemed to run a little smoother today after two 22-mile commutes to and from work. I'll hope it continues to improve. Lesson learned. I probably owe it to others to at least report the incident to the BBB.
  10. firegirl
    firegirl New Member
    kauai
    2003 Prius
    Ok. Aloha. I now find myself at actII -now what? I see that I am not alone in being frustrated with my dealership. I took the car in three times and was told it was ok. diagnostic when I complained of rattling came up clean. Then I am told the whole rack and pinion needs to be replaced (2k for the part). have been driving it and is just getting tighter and tighter - is that what you meant about Act II? if so -is it replaceable?
    thanks
  11. tochatihu
    9,855
    3,815
    2001 Prius
    Does tighter and tighter mean that more effort is required to steer? If so, this means that the power assist is offline. There should also be an error display. Re-starting the car should bring back power assist at least temporarily.
    Toyota does not replace this system piecewise - it's the whole thing and now you know their price. Used ones are available and you might consider that option.
    Kauai is a beautiful island but perhaps expensive to get heavy things shipped in. Also I imagine that you have one and only one Toyota shop in Lihue, so you pretty much have to deal with those guys.
  12. ca02prius
    2002 Prius
    I'll be interested to hear what tochatihu has to say about this. In my case, I'm still struggling with the shuddering that now occurs when turning the wheel quickly to the right, and I'm wondering whether it's worth it to take it back to the dealer who can now claim no responsibility, as I had the rack & pinion replaced by a non-Toyota mechanic. I'm still awfully attached to the car, so I've been very careful to turn the wheel very slowly whenever turning right. Don't know how long I can keep this up, though.
    The fact that your dealer couldn't find anything wrong after several visits MIGHT give you some leverage, but I don't know. How many miles do you have? Any other issues? Might it still be under some sort of warranty? I do hope you get a response from someone knowledgeable. Are you as attached to your Gen1 as I am? (Don't know why I can't get excited about the newer models, but they're so ubiquitous here in CA to the point of being boring!)
  13. tochatihu
    9,855
    3,815
    2001 Prius
    ca02, if you're wondering how the shop will respond to the current situation you might as well take it in and find out.
    There is a computer (ECU) associated with the power steering assist, but I really don't know if it is typically replaced along with the electromechanicals. AFAIK there has been no clear indication from Toyota that they ever altered the ECU program for the 01-03 model.
    I was all set to report that www.car-part.com has a bunch of these (as takeouts) but at the moment I see only one listed. LKQonline is another potential source.
  14. ca02prius
    2002 Prius
    Thanks, tochatihu. As you can see, I haven't given up on this yet. After reading a re-reading several posts, I think I'll ask the dealer again (or the other one in SJ) and/or call Art's Automotive in Berkeley, even though they are a bit of a drive. I'd hate to spring for another ECU only to find out that's not the source of the problem. It's so easy for each shop to blame the other, though I wish I knew if I had any recourse at all with Pep Boys. It doesn't seem like it since I refused their "offer" to replace the ECU for another $800+.
  15. rosepetal
    rosepetal New Member
    eugene, ore
    2002 Prius
    hi folks, i am wondering an average in your experience how long it takes for the steering gear to go completely out. i am from eugene, oregon down here in santa cruz on "vacation" . coming down here my warning lights went on, PS, the "main" with battery sign, and the triangle with the ! in the middle. i stopped and the nearest dealer said it was the invertor pump which was replaced for $400. got back on the road. 60 miles later all warning lights were on again, :( :(. go off a few minutes later and then about a 1/2 hour later back on, power steering is not working. ugh. by this time i am on the cali coast no where near any toyota dealer so i continue on to my friends house, and turn off the car. then i move it 5 minutes later and no lights are on now. when i bring it to the santa cruz toyota dealer, they tell me the steering gear rack needs to be relplaced. a used one is the only option as i am a low-income single mama. so, it looks like i have to drive back up to eugene because i don't think i can find a good used part in time as i am only here until monday. (today is thursday)
    i am worried about driving back up. any advice?
    thanks!
  16. bwilson4web
    16,392
    Interesting symptoms
    That should have included replacing the inverter coolant. Check your receipt to see if coolant was included. The problem is bleeding the coolant can be tricky.
    Open the hood and there is a reservoir to the left of the inverter. It should have a pinkish or redish colored fluid equal with the fill line. With the car turned on, you should see coolant flowing.
    If the coolant bleeding was insufficient, you may be low.
    After three restarts, the car will clear the error indications but the codes will remain in memory.
    I hope they checked the inverter coolant level and flow ... you would think.
    Did the receipt include any codes?
    If you drove to and from the dealer, it should be OK although hard to steer. The power circuit to the power steering ECU shows:
    • 50 A fuse
    • EMPS relay
    Assuming they checked these, it might be useful to find them before heading back, especially the fuse. If you have a steering problem on the road, pulling the 50 A fuse would be a safe thing to do and continue on your trip.
    If you open the hood, on the left rear is the fuse box with the 50 A, EMPS Fuse and EMPS relay. When you get a chance, see if you can find it and for grins, see how to open it and inspect the fuse. The EMPS relay is also there.
  17. Patrick Wong
    18,210
    6,514
    When the power steering assist went out, did you have any trouble controlling the car?
    Did you notice unusual vibration or twitching in the steering wheel?
    The issue with the steering gear is that the torque sensor potentiometers buried within, which tell the power steering ECU how much power assist to provide, are beginning to fail. This results in loss of power assist and the steering wheel often begins to twitch.
    Sometimes, if you rotate the steering wheel full counter-clockwise to full clockwise, and repeat several times, that will clean the torque sensor potentiometers and give you temporary relief.
    As long as you are aware of the potential loss of power assist and steering wheel twitching, and can control the car regardless, then you can safely drive the car back to Oregon. Good luck.
  18. pshawfocus
    pshawfocus Picard would own a Prius...
    44
    London, UK
    2001 Prius
    Hi Patrick
    Just jumping in on this thread as my 2001 Prius power steering is very, very heavy. There’s definately some power assistance there but twirling the wheel around for parking is far more arduous than is should be. I don’t have any twitching but am wondering if there is any connection with the cause / effect you mention above re the torque sensors / power steering ECU. I’m on 111k miles and (touches wood and strokes unicorn) my wonderful car performs very well.
    Interestingly enough, when turning the car off, the assistance suddenly increases to what I would consider to be normal levels; that moment when you remove the key and can adjust the wheel to get the steering column lock to catch. At that point the effort needed is effortless, literally one finger. But in normal, low speed parking it’s very heavy. Naturally when on the move the car’s speed helps lighten the load but I still get the sense that the steering assistance is quite minimal.
    Anyway, sorry for the long ramble. Hoping someone has some bright ideas. Thanks in advance
    Gary
  19. ChapmanF
    18,613
    Interesting ... that wasn't something I had noticed when mine was acting up, but maybe I just didn't notice. I would pull off the road and just turn the key off and back on to get my assist back.
    I had noticed, on earlier occasions, the way the Gen 1 does maintain assist for a brief while after being turned off, to make your final adjustment easier. (My Gen 3 does not, the steering goes heavy immediately on power-off. But Gen 3 doesn't lock the steering column, so you don't have any final adjustment to make.)
    The Gen 1 steering ECU controls its own power relay, just so it can do that trick for you. (Another thing I had noticed was that, after power-off, it will stay powered up to power the torque sensor for even longer—a minute or two—than it continues providing assist power. That provides a nice interval where you can twist the wheel and measure torque sensor voltages without being thrown off by the assist trying to respond to them while you're measuring.)
    So maybe they built it to wake back up for those last moments after power-off, if it had given up earlier.
    We're well past the extended warranty now, so the options might be limited to looking for a new ($$$), used (???), remanufactured (I think Cardone offers one, or did) steering rack, or trying to clean up your own torque sensor:
    You might be a pioneering PriusChat experimenter if you try, but I think it would turn out (except for the exhausting effort of getting the rack out of the car and the sensor out of the rack) to be not much different from cleaning off the other potentiometer-based sensors in the Gen 1 that get noisy over time, like the accelerator or the heater servos.
    I have a GC product called Jiffy Bath that can be rubbed on with a cotton swab, to clean and then leave a very light conductive lubricant behind. If there appears to have been a slightly heavier grease used originally, one might consider Motorcraft XG-12, which isn't hard to get, after first cleaning the contacts.
    I've never tried cleaning up a rack, I guarantee nothing, you're on your own. :)
    pshawfocus likes this.
  20. Patrick Wong
    18,210
    6,514
    My idea would be to check the fuse and relay described in post 16 and if those are good, obtain a replacement steering rack.
