2002 Prius Starting Problem temp below 25F
Discussion in 'Generation 1 Prius Discussion' started by engrx2, Dec 10, 2009.
  1. engrx2
    engrx2 Junior Member
    17
    Indianapolis
    2002 Prius
    Whenever temperature is below 25F the engine starts and then shuts down with in 20 seconds. Ready sign stays on and I can drive on battery. Check engine and warning triangle also comes on. It starts again after few tries and if I shift into drive right away and start driving the engine will stay on.
    No problems after that as long as engine is hot. Warning lights also go away after a stop and starts.
    Same thing happens if the car sits in cold for a few hours.
    Does anybody have any ideas where to start troubleshooting?
  2. dogfriend
    7,512
    1,189
    Carmichael, CA
    Maybe a sticky throttle body? I believe that will sometimes cause a "no start".
  3. bwilson4web
    16,007
    Symptoms are consistent with sticky throttle plate.
  4. lorraine
    lorraine New Member
    39
    monroe, ny
    That should not happen. I started mine right up this morning and it was 16 degrees.
    Lorraine
  5. tf4624
    tf4624 Active Member
    527
    51
    besdies fixing the throttle plate.. TIME TO INSTALl a block heater LOL:rockon:
  6. Gardinia
    Gardinia Junior Member
    2002 Prius
    I had the same problem until I had the throttle cleaned. My warning light had been on close to half the winter in other years. I live in MN. I had this done last fall, 2009, and haven't had the engine kill or the warning lights come on!!!! My mechanic said this is a problem on other Toyota models as well.
  7. tochatihu
    tochatihu Senior Member
    9,546
    3,681
    Kunming Yunnan China
    2001 Prius
    All hints above should help. There is also a slight chance that you have engine oil of the incorrect (too high) viscosity.
    A healthy Prius will fire up at -40 like few other vehicles. Fuel economy is strongly reduced but she runs.
  8. treet007
    treet007 Member
    102
    Ireland
    2019 Prius
    There is a TSB (Technical Service Bulletin) on a sticky throttle body for 2001-2003 Prius. I suggest contacting Toyota service for details, or check http://www.alldata.com/
    I had my 2002 Prius' throttle body cleaned when I received my letter from Toyota.
