2002 replacement hybrid battery, dealer warranty only one year?
Discussion in 'Generation 1 Prius Discussion' started by Debora, Oct 26, 2015.
  1. Debora
    Debora Junior Member
    My Toyota dealer just said I need to replace the hybrid battery in my 2002 Prius for $3627.00. They quoted only a 1 year warranty on the new replacement battery. Is it really only a one year warranty?
  2. greasemonkey007
    greasemonkey007 Active Member
    286
    104
    South Central Arkansas
    Yes, it is. You can buy a Dorman battery rebuilt with 2nd gen modules and a 3 year warrany for around $1500 plus installation. Install should be no more than $200. Dorman can possibly refer you to an installer in your area. Where are you located? I repair/install batteries around central Arkansas and would be glad to help if you're near here.
    48,984
    it's a new battery, so will probably last as long as the original. the warranty on any replacement part from toyota is one year.
  4. ericbecky
    ericbecky Hybrid Battery Hero
    4,365
    3,209
    Madison, Wisconsin
    Nearly all replacement parts from Toyota will carry a 12 month, 12,000 mile warranty.
    Hybrid batteries are no different.
    The reality is, of course, that they will last as long as the original battery.
  5. aswresm
    aswresm Junior Member
    50
    2002 Prius
    I
    Put an ad on Craigslist in your area for anyone who can rebuild your own battery...It wouldn't cost you more than $500...Another option is to look around for Hybrid repair shops in your area, they are a bit more expensive and they will not rebuild your battery as they will better make more money swapping it with one that has been already rebuilt. Good luck.
