Little back story. Last year during an unusually rainy spring I had the red triangle and brake warning light come on while driving. Kept driving normal until i parked it. Once park i could not get it to go into drive or reverse, only neutral and park. Pull the negative on battery, let it sit, hook back up and down the road i go. This happened several time during the rainy season. Once the we went into our normal texas dry spell the car was fine. Fast forward to present. Went to have new tires put on and on the way home i come to the turn off to my house. Im slowing down, assume the engine shuts off like noral as im coasting and when i turn onto my street and press the gas pedal engine does not come back on and red triangle and brake warning light comes on. Im a few 100 yards from home so i go the rest of the way on electric. get home, unhook battery , hook battery back up and nothing. Red triangle, brake warning light and no Ready mode and no engine start. scanner showed code for gas pedal malfunction. replaced it, still nothing. only other code is PAO94 for dc/dc converter performance. Ive checked all fuses, fusible link, verified my 2 year old axillary battery is good. No repair shops withing 100 miles of me. Any help would be greatly appreciated.
What was the actual trouble code you saw, not the verbal description. What scanner are you using to read trouble codes?
P0A94 (DC/DC Converter Performance) and P1121 (throttle/pedal position sensor/Performance problem/coolant flow control valve position sensor circuit stuck). I changed the pedal assembly, no change. Ive had the CE light on for 5 years due to the coolant flow control valve. Had a toyota mechanic tell me not to worry about changing that. The scanner was a local GM certified mechanic with his SnapOn scanner. It was probably only pulling codes on the "surface" and not ones deeper in the system.
If DC to DC is fubar 12 v won't charge . So at ready you'd see like way less that 13 v etc the 12v going down . As it not charging . DC to DC is essentially you're alternator
I checked voltage with power off and it was 12.7V. Hit the Power Button and voltage jumps to 14V, but no Ready light and no engine start. I even put a battery charger on it to bring it up to 13.1V, put a jump box on it at the distribution area and still nothing.
best to get a free load test at most auto parts stores. if it is good, check the jump point under the hood to see if there is a wiring issue. the mention of rainy spring on a 20 year old prius makes me think corrosion on an ecu wiring connector best-way-to-clean-this-hybrid-control-module-connector-v0-pg7vrdg70toa1.jpg
bisco: 2 year old battery. I charged it up and took it in and had them load test it. They said it was good.
That's not surprising as P1121 has nothing to do with the throttle or pedal sensor. That is a catch-all fortune cookie phrase to cover that code in multiple cars and/or models. The part of that phrase that is applicable is "coolant flow control valve position sensor circuit stuck". The best advice is to look up Toyota Prius DTCs in the Toyota Prius repair manual. The P0A94 has several sub-code that would help in the diagnostic effort. If you can share which sub-code your car has here that would help.
The fortune cookie for P0A94 does say DC/DC converter, but it doesn't mean that one. (There are old posts where I made the same mistake myself before I knew better.) The other DC/DC converter in the car is the one that boosts the battery's 201.6 VDC to 500 VDC for the MGs. That's the one P0A94 is about.
Ive tried several time to "reboot" the system. Could this fault be locked in preventing engine from starting despite fully charged 12v battery and jump system?
You can take a look at this picture. It's one we normally use for the P0AA6 code, which you don't have. But the picture shows you the parts of the system. See the box labeled "Boost Converter" in the picture? That's what the P0A94 code you have is about. Toyota usually calls it the boost converter, and Toyota usually uses "DC/DC converter" to mean the one supplying the 12V. But the "boost converter" is also, technically, a DC/DC converter, and that's what SAE calls it, and all P0 codes are SAE standard codes. You can see from the picture that the boost converter supplies the inverter that drives MG1 and MG2. MG1 is what cranks the engine to start it. If the boost converter isn't working, that can't happen. The code is to tell you what the problem is. The problem itself is what has to be fixed.
Sounds like it's time for a quick trip to a local salvage yard or craigslist to buy an inverter assembly for $50. Just swap the whole thing. Probably 2 hours start to finish taking your time.
Just swap out a inverter from gen3 type with a sticker on it that means all campaigns done on it . Can be free from many places they predominantly get thrown out I don't think these things there's no. Money in so they trashed mostly or metal recycling or weight to a salvage operation . There might be a few here if you're in the southeast
It just so happens I have a wrecked prius at home. My son took out a Chevy Tahoe with it. I knew I kept it for a reason.
Wanted to let you know I got my car back on the road. Pulled the inverter off my wrecked prius and dropped it in my daily. I surely appreciate you sharing your knowledge.
